muffler finish
Old Dec 21, 2011 | 08:22 PM
9492's Avatar
9492
Default muffler finish
Page 100 of the 1970-72 NCRS technical information manual and judging guide says that mufflers were painted with a black- out spray. Is this correct? I believe the mufflers on mine to be original. They are galvanized with no black-out paint.
Old Dec 22, 2011 | 04:09 AM
hunt4cleanair's Avatar
hunt4cleanair
It wasn't until 78 when mufflers left St Louis with no black-out. I don't recall if its Allen but there is a group that reproduces original looking exhaust systems for the early C3 Corvettes. So, your system could be one of those...but never blacked out.
Old Dec 22, 2011 | 08:55 AM
9492's Avatar
9492
I should have mentioned in my original post that according to the Corvette 1968-82 Restoration Guide there is no mention of black-out on mufflers. It indicates that 70-72 mufflers had a galvanized finish. It shows several examples of non-restored mufflers with no black-out. I want my restoration to be as correct as possible and wanted to know which source is correct.
Old Dec 22, 2011 | 02:11 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...I want my restoration to be as correct as possible and wanted to know which source is correct...
Go with the NCRS. They're blacked out on this 69:
Not blacked out on this 81:
Old Dec 22, 2011 | 02:31 PM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
Every original exhaust that I've seen on a 1968 to 1972 Corvette has the mufflers blacked out. White paper part number tags on each muffler/rear pipe assembly and each exhaust tip... Part numbers for the forward pipes stamped into the tubing at the rear of each pipe.
There are no absolutely perfect aftermarket pipes/mufflers out there. Gardner's is the best, but still requires some work to make it look ok as far as judging goes. Even then, you'll probably lose a couple of points in NCRS judging.
Regards,
Stan Falenski
Old Dec 22, 2011 | 02:34 PM
Alan 71's Avatar
Alan 71
Hi 9492,
I believe the mufflers did have some black-out paint on them. I believe it was on the lower portion, and rear, of the muffler seen when the car was sitting on the ground. The idea was to make the muffler less noticeable when looking at the car.
It was a very quick job as was the rest of the black-out.
If in fact you do have the exhaust system your car left St. Louis with I'd think the paint could be gone after all these years. A production line exhaust system is a REAL find!!!!
Regards,
Alan
To muffler finish
