The back sits up too high??
Old Apr 8, 2012 | 10:49 PM
alconk's Avatar
alconk
Default The back sits up too high??
I asked this question once already but didn't do anything about it so it's just a refresher. My 82 sits up way too high in the rear but was told I can lower it by loosening the mono leaf springbolts?? I looked under there and there is a castle nut with a cotter pin and if I loose it I will not be able to use the cotter pin because the hole will be covered up. Is this the nuts they were talking about?? I have a 4" clearance from the top of the tire to the fender lip (maybe exagerating a little). If anyone would have a picture of what nut I need to loosen that would be greatly appreciated. No I do not have air shocks but need to be replaced. Could that make a difference?
Old Apr 8, 2012 | 11:06 PM
Redwing01's Avatar
Redwing01
2015 C3 of Year Finalist
=4" +\- doesn't seem that bad really.
Got any pics?
Old Apr 8, 2012 | 11:26 PM
77BLACKNSMOKE's Avatar
77BLACKNSMOKE
============Dont go with out the cotter pin. ===========
You can order longer bolts from most venders. That will lower the back of the car. Then if it is to low. You can just tighten up the bolt. Till you have the height you want.
Old Apr 9, 2012 | 04:37 AM
alconk's Avatar
alconk
But what caused it to sit higher than normal? I would rather use the original bolts. I'll take a pic. later
Old Apr 9, 2012 | 07:54 AM
73Corvette's Avatar
73Corvette
You could beef up some.....go to the buffet as often as possible and top it off at Braums for a sundae....SuperSlam at Dennys every morning followed by a trip to Winchells for a dozen donuts...LOTS of Micky D's burgers and fries.....NEVER ever exercise. May be a little hard on the seat frames but could lower the car a bit........
Old Apr 9, 2012 | 07:58 AM
U17's Avatar
U17
Naw .. I tried all that... Had to get the longer bolts ...
Old Apr 9, 2012 | 09:08 AM
Alan 71's Avatar
Alan 71
Hi alc,
You asked "what's causing it?"
One possibility is that your car has a replacement spring installed on it, perhaps one with a higher rating.
Changes in the rear spring OFTEN cause a car to have the ride height to be too high.
With the stock spring and tires, and ALL the parts on the car, there should be about 2"-2 1/2" between the top of the tire and the top of the wheel arch.
The longer bolt cures the result, but not the cause.
Regards,
Alan
Old Apr 9, 2012 | 09:31 AM
damoroso's Avatar
damoroso
How much clearance between the front tires and fenders? What size wheels and tires are on the car? A full tank of gas makes some difference too, but I think Alan 71's probably right, the spring may have been changed.
Old Apr 9, 2012 | 10:02 AM
den(thevetteman)78's Avatar
den(thevetteman)78
Mine is sitting high too but at all 4 corners. What should i do to lower it down? Specially the front as i know that the rear spring had been re-arc but it never went lower then that after 20+ years i will have to use longer bolt.
Old Apr 9, 2012 | 12:12 PM
alconk's Avatar
alconk
Originally Posted by Alan 71
Hi alc,
Regards,
Alan
Hello Alan,
In the front there is about a 2" gap but the rear is very open between the arch and tire. I've look at maybe replacing the spring and all I want is original and they have different spring rates. Not sure what mine is.
Old Apr 9, 2012 | 12:31 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 77BLACKNSMOKE
...Dont go with out the cotter pin....You can order longer bolts from most venders...
Old Apr 9, 2012 | 12:38 PM
alconk's Avatar
alconk
I found the longer bolts but they don't use a cotter pin and cattle nut. It's just a nylon locking nut. Would that be safe??
Old Apr 9, 2012 | 01:32 PM
gdh's Avatar
gdh
Den, you can cut the front spring down - but start by 1/2 initially until you get the desired height. We're the fronts replaced to gain that height?
Old Apr 9, 2012 | 02:48 PM
alconk's Avatar
alconk
Here is a picture on how it
Old Apr 9, 2012 | 02:57 PM
alconk's Avatar
alconk
That's funny, I meant "castle nut"
Old Apr 9, 2012 | 03:00 PM
alconk's Avatar
alconk
Old Apr 9, 2012 | 03:07 PM
den(thevetteman)78
Yes i think the were change before i bought the car 23 years ago. Because when i bought the car they looked brand new. I think they are 460lb Front Coil Springs. I've heard that those after market coil spring have tendency to raise the front a bit.
To The back sits up too high??
Old Apr 9, 2012 | 03:11 PM
gdh's Avatar
gdh
I have 550 lb fronts on and mine sits very nicely with no modification.
Old Apr 9, 2012 | 03:18 PM
Alan 71's Avatar
Alan 71
Hi alc,
Yes it certainly is high.
If you could post some pictures of the rear suspension someone might see a problem, or recognize the spring you presently have.
That will help determine what you might be able to do.
Regards,
Alan
Old Apr 9, 2012 | 03:46 PM
den(thevetteman)78
Was it always like that ?
I really think you will need this 8'' long bolt kit.
