Biggest Regrets?
Old May 17, 2012 | 01:42 PM
Stroh's Avatar
Stroh
Default Biggest Regrets?
So many of us are either restoring, modifying, or "improving" our 'vettes by mining the rich information share here, that I was thinking a thread of the "I wish I woulda thunk it or done it" things we only discover in hindsight might be useful to a lot of folks. I know I do and will appreciate information, hints, tricks, and so forth that I can pick up here.
So what have you done only to discover you wish you would have done differently?
I know I have a few of my own...
I'd definately have saved the old carpet to mark holes before installing the new carpet.
I'd definately have bought all interior screws from Wilcox before hunting them down one set at a time from local vendors, which took FOREVER.
I'd have crushed, cracked, set fire to, and otherwise blown up the flimsy piece of crap original interior back window frame before wasting a second trying to repair, reglue, cover it etc.
I'd certainly have baggied and labeled EVERY screw I took out of my 75 along the way.
And I've definately have taked lots of before pictures as I deconstrcuted anything (especially wiring).
All of this advice I've found here AFTER the fact, so maybe a "make sure you do this" list will help.
Old May 17, 2012 | 01:54 PM
MrJlr's Avatar
MrJlr
I would have bought a Vert.......
Old May 17, 2012 | 02:00 PM
scottw's Avatar
scottw
Woulda put in a crate engine 5 years ago instead of a few months ago.
Old May 17, 2012 | 02:05 PM
briankeery's Avatar
briankeery
So far Leigh, I've actually tried to learn from other's mistakes(sorry guys!!) here on the forum. I've only had a couple of minor things pop up; but by starting to research here, I've definitely been able to save some time - and more importantly, money.
I think the biggest thing I've learned is to know my limitations, and realize that sometimes the car needs to go to a pro for certain jobs(in my case a rear wheel alignment). You can pay a little now, or a lot later.
Old May 17, 2012 | 02:12 PM
Stroh's Avatar
Stroh
Originally Posted by mrjlr
i would have bought a vert.......
amen!
Old May 17, 2012 | 02:13 PM
rogman16's Avatar
rogman16
If I could go back in time, I would've at least drove the car around the neighborhood before dis-assembly... I wish I would've taken more pictures of the car before the tear down... Sure there are a million more, but those are my biggest regrets so far...
Rogman
Old May 17, 2012 | 02:17 PM
Stroh's Avatar
Stroh
Brian,
Absolutely right! Knowing when five hours of my messing it up worse isn't the answer is a huge regret. Also a huge education, so certainly not a total loss.
I can handle sliding the alternator out once the belt stretches to get rid of the rev squeek. I can handle troubleshooting wires and replacing plugs. I can handle clean ups and redyes. And some audio work. I have learned how to handle the PITA vacuum system. But a lot of the engine and fuel line issues need to be handled by a pro or I'll end up blowing up a motor or myself. Neither idea sounds too good to me.
And Brian you're right about time and money... I've got more time than money, but when it costs a lot of both it's time to bring in the people who really know what they're doing... Unlike me who just think I do.
Old May 17, 2012 | 03:10 PM
Mgrad92's Avatar
Mgrad92
My Vette is my second "fixer upper" so I learned a lot at the expense of my first car.
And even though I know better, I still don't take enough pictures before disassembly. The problem is that you never know exactly what angle you should take the picture from until you're reassembling the parts.
The big regret I have about my current car is not asking enough simple questions. I already blew out a set of speakers that were rated to handle what my stereo was putting out because the speakers were crap. Had I asked what other were using, I would have saved myself some time and $$.
Old May 17, 2012 | 03:31 PM
keithinspace's Avatar
keithinspace
None yet. Other than I SHOULD have purchased the car 10 YEARS ago instead of 5 MONTHS ago.
I've been having WAAAAAAY too much fun with her (Bella, we call her...my mistress) for it to actually be legal!
"Corvette Therapy" is now a coined term in my house.
Old May 17, 2012 | 03:43 PM
LOTSARED's Avatar
LOTSARED
Default regrets
I would have decided up front to take the body off the frame instead of wasting days & neck aches trying to "restore" the chassis from the underside. Removing the body is a weekend job and then it's so easy to do the chassis.
I should have jumped to stainless brakes right away instead of cursing over the annual brake work every spring.
I should have kept my original 1968 carpet and just re-died it. The new carpet (yes the "good" stuff) showed more wear after 2 years than the original did after 30 years!
Beyond that, it went well. Here are a few tips that I do not regret:
Installed good undercarpet insulation.
While the interior was out, I routed wiring for a hidden kill switch... a simple anti-theft device.
I did not over-restore. When rechroming the 427's valve covers I chose not to fill the visible dimples from the oil drippers. This way "they are what they were".
I photographed the fragile build sheet on the gas tank before removing it for safe keeping.
Old May 17, 2012 | 03:47 PM
7T1vette's Avatar
7T1vette
I should have pulled the engine in order to refurb the engine compartment. But, since the engine didn't need a rebuild, I left it in place. Had I pulled it, the entire process of renovation--particularly the engine itself--would have been SO much easier to work on.
Old May 17, 2012 | 03:49 PM
nate99's Avatar
nate99
Should have waited another year or two and bought a car that wasn't such a basket case.
Old May 17, 2012 | 04:12 PM
Jeff_Keryk's Avatar
Jeff_Keryk
Not buying that nearly perfect blue 67 327 Roadster for 22K. It needed nothing. Oherwise nothing; my educations is bought and paid for.
Old May 17, 2012 | 04:14 PM
my 76 ray's Avatar
my 76 ray
I painted the outside of the frame before deciding how to coat the inside for rust prevention. The product I decided to use on the inside is green and I got some on the outside. The good news is I already know what I'll use on the inside next time.
Old May 17, 2012 | 05:12 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
Only regret - buying at the top of the market! Could have saved about $5K by waiting.
Old May 17, 2012 | 05:13 PM
oldgto's Avatar
oldgto
That`s my vote, only regret is I waited TOO long before adding a `Vette to our collection!
Old May 17, 2012 | 05:18 PM
TimAT's Avatar
TimAT
My regret is not being in a position in 1969 to purchase a pair of the ZL-1 Vettes along with some of the other "muscle" cars of those days. Then I could sell one now and then and retire very comfortably
To Biggest Regrets?
Old May 17, 2012 | 05:32 PM
noonie's Avatar
noonie
You could have bought all 6 of the 70 Hemi Cuda convertibles new then and BJ'd them about 5 years ago.
Maybe even a used Tucker.
Old May 17, 2012 | 05:56 PM
jordan89's Avatar
jordan89
Rogman
Same here. I didn't even put it up, nor did I bring it down from the trailer, when I brought mines home. I tore it apart the next day. I wish I would have just freshened things up and drove it before doing what I'm doing to it now. I barely put up the pumpkin yesterday. The Front is pretty much done.
Old May 17, 2012 | 07:03 PM
Clams Canino's Avatar
Clams Canino
I wish I hadn't orphaned "Old Thirsty" up in NH when we moved to SC.
When I finally got it here, it was like a bad barn find, only I found it in my own barn!
Click for larger image
