Tire Pressure ?
Old Jul 5, 2012 | 07:39 AM
mk's78's Avatar
mk's78
Default Tire Pressure ?
Hello and a Happy 4th to all,
I am running Firehawk Indy 500 P225/70R 15's on my 78 SA non daily driver......would 35psi be too much?????
mk's78
mike
Old Jul 5, 2012 | 07:42 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
30-32 cold is about the sweet spot with radials
You will ride harder at 35 lbs and may wear them a bit faster in the middle.
Old Jul 5, 2012 | 09:47 AM
7T1vette's Avatar
7T1vette
Yes. For a larger-than-stock tire, 35 psi is too much for normal driving. As mentioned, that will provide a firmer-than-normal ride, but will cause tires to wear in the center. It will also diminish braking capability, as there is a smaller tread footprint on the pavement. 30-32 psi is probably best for your tires. I keep mine (235R60-15) at 30 psi.
To Tire Pressure ?
