Numbers matching?
To some, the mere "match" of the VIN stamped on the windshield pillar or dashboard matched against the assembly date VIN derivative stamped on the block is sufficient to claim numbers "matching". There are only a few "numbers" that can match "each other" -- which actually refers to the vehicle VIN (on windshield pillar and VIN derivation on the block. The VIN should also match your build sheet (tank sticker) and/or window sticker and/or Protect-o-plate.
The real test is not only numbers "matching?" but is the car numbers "correct".
THAT is the more important test of value and originality. If matching is important, than so should be "correct". What's the difference if the block is correct if everything else is wrong?
The block VIN and windshield pillar VIN may match, but that's just the tip of the iceberg. Other "numbers" (not just dates) to be TRULY numbers matching & correct would include (but not limited to):
-intake manifold
-heads
-water pump
-starter
-carb(s)
-Coil
-Distributor
-Wires
-Master cylinder
-Windshield washer pump
-Radiator
-Radiator Cap
-Horn
-Air Filter
-Oil Filter
-Exhaust Manifolds
-Alternator
-Shocks
-Battery
-Fan blades
-AC compressor (if present)
-Transmission
-Rear-end
-Chassis
-Wheels (each is stamped and dated)
Evaluating that "the numbers of the parts match what was installed at the Factory" is a more complete measure of how original / correct the car is -vs- does the block match the VIN (which is a starting point). I should add that if the VIN on the block doesn't match, depending upon what that VIN assembly date is, it may in some cases be an acceptable and recognized equivalent of "matching" to collectors and certain organizations like NCRS (if the dates are within 6 mos. prior to the body build date, it can be treated as original -- even though within 2 weeks seems to be the norm for an original)
and then how about the Trim Tag. Does the paint match the codes? How about the interior?
-Is it the correct hood?
-Windshield replaced?
-Correct glass side and rear?
-Correct Radio?
-Correct Carpet?
-Correct Seats?
-Door Panels?
-Steering wheel?
Another test is does the Tank Sticker/Build Sheet options match what's in the car? Is the car Truly an LT-1 or did someone change the engine & hood?
Is the paint color correct? Etc
Opinions may vary...
you state car is already top flite and if it truely is , so how much better could you want it? Correct dated transmission would be fine with me to fit your cars build date.. Any soft aluminum trannie, can be restamped with a correct vin # easy as 1-2-3, so I wouldn't worry about this, LONG as you know the INSIDES are CORRECT , example be sure it is built as a M22, iF that is what you are paying for... So I wouldn't let this trannie stop you from buying the car if you like it. Any and all can be corrected. Axles have no vins, just find a code w/close date one and restore it.
For me ..Long as the engines block is cool (original) factory installed motor undecked with grain and hasn't been restamped sounds great to me., I would be VERY picky about the heads though.. I would want verification of the head dates, marks, ect, after all this is big part of the cost of this car. They should have all the pics ,if they want the big money.
Correct carb, intake, dizzy, waterpump, air cleaner, exhaust manifolds, bellhousing, starter, pulleys ect should have correct part numbers and date close as possible. Stuff does wear out (shocks, tires , carpet, seat covers) and get replaced over the years and trannies explode sometimes too. Rear ends got swapped all the time back in the day ....nothing that can't be found or bought at a price. .
Once you find the car you want,
Do not purchase any rare Corvette without having it authenticated by a professional Corvette inspector for the specific generation of the car ( C-1, C-2. C-3 ect ).
Also if it is really rare ( Expencive ) have more than 1 inspection by different inspector's .
The best money you will ever spend !
Bill
Have you seen the documents - the judging sheets are returned to the owner after the car is judged.
LOTS of things can happen to a "Top Flight" car once it leaves the judging field - rare parts come off, etc.
Where was it a Top Flight car?
A Top Flight at a Regional or National NCRS event is more meaningful than a Top Flight awarded at a Chapter (local) event. National/Regional events are more likely to have experienced judges for all sections of the car.
IMO: If you are interested and the car is $$$, then get a knowledgeable person to examine it.
Maybe the car you're looking at has the numbers you'd expect to see on an original car. How do you know it's not a good restamp? NCRS judging does NOT determine or certify that a car has it's original engine (or anything else).
Where is the documentation? For your car to be considered 'factory correct', you need to have the paperwork from the dealer who swapped out the transmission. Also, the frame [VIN] number and engine numbers need to match the window frame rail VIN number. And, if you expect to do well going for NCRS awards, the stamped/cast/molded part numbers on detail parts need to be correct with what the factory installed on your car and the date codes need to be reasonably close to (and not after) the production date of the vehicle.
If those things aren't right and if the paperwork is non-existent [reproduced or in shoddy condition], you shouldn't pay much of a premium for that "numbers matching" car.
M. Ward must be the only "real car guy" here, based on his contrived definition...
-intake manifold
-heads
-water pump
-starter
-carb(s)
-Coil
-Distributor
-Wires
-Master cylinder
-Radiator
-Radiator Cap
-Horn
-Air Filter
-Oil Filter
-Exhaust Manifolds
-Alternator
-Shocks
-Battery
-Fan blades
-Transmission
-Rear-end
-Chassis
-Correct Radio?
-Correct Carpet?
-Correct Seats?
-Door Panels?
-Steering wheel?
Also the car has full owner history and some owner interviews but no tank sticker, protecto plate etc.
Still can't resist going for the jugular at every opportunity, huh? It's getting old.
If you have concerns about the car's authenticity and value, then so will the next caretaker you try to sell it to. Think about it.
Cars can only be original once, and that goes for the entire car. If the original transmission is gone, the car is no longer original...period...in a major way. It has now been relegated to some lesser category. Too bad, an all original L89 is quite rare. There are many wannabes out there.
I was commenting on your statement that "real car guys" don't use the term 'numbers matching'. Well, lots of folks do use that term. And, you don't...so you must be the only real car guy around!
Aren't you "special"?
Regards,
Stan Falenski
ALWAYS confirm that your definition of numbers matching is the same for the buyer and seller. It rarely is the same.
Assuming yes, then is the block matching worthy of increased value OR is the original block AND all of the original pieces bolted to it what is truly the thing that adds value?
