Speedo test question
Old Aug 14, 2012 | 05:14 AM
briaineo's Avatar
briaineo
Default Speedo test question
Hey
My speedometer has never worked so I removed the cable from the transmission, I had someone look at the speedo while I ran the drill, the needle shot up a bit but then nothing at all.
Any idea what this could mean? I have never looked at a speedo system before.
When I unscrew the cable from the transmission and remove the nut and Tab how do I get the gear out? Does it just pull out with the brass threaded part?
thanks
the cars is a '69 and I think it is the original 4 speed trans. I only got partial codes with me the casing was stamped 3857####### and the was a vertical number P9R08H (unclear picture I took)
One last question what does the large 13 and small 9 stand for below the General Motors Corp
Old Aug 14, 2012 | 08:39 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by briaineo
...Any idea what this could mean?...
Bad cable or the cable end has backed out of the speedo head.
Old Aug 14, 2012 | 12:35 PM
7T1vette's Avatar
7T1vette
...or the speedo head is defective.
To Speedo test question
