Outer Door Seals ?
Old Nov 12, 2012 | 05:15 PM
CoolKars's Avatar
CoolKars
Default Outer Door Seals ?
I purchased a set of outer door seals for my 1970 coupe (The best available).
"No imitations here! Tired of parts that are kind of close and kind of work?
Then be assured that these outer window seals from ?? ?? are
correct. ?? ?? has built the tooling to produce outer window seals
that are correct in every detail - correct material, correct beading , and correct
bends. Don't accept imitations . . . use ?? ??l seals that look right
and perform as they should."
Has anyone had the problem of the seals being too long and the pins not aligning? It is too long where the door closes.
Thanks,
CK
Old Nov 12, 2012 | 08:51 PM
CoolKars's Avatar
CoolKars
Cannot seem to get images from photobucket to work. Used please enter URL of images. Need help please.
Old Nov 12, 2012 | 10:05 PM
CoolKars's Avatar
CoolKars
Finally, got images to post.
Old Nov 13, 2012 | 08:42 AM
Alan 71's Avatar
Alan 71
Hi ck,
I believe coupe and convertible are different in length... did you order/receive the right seal?
Here's the fit on a coupe.
Regards,
Alan
Old Nov 13, 2012 | 11:05 AM
CoolKars's Avatar
CoolKars
Hi Alan,
I did order and receive the correct part for a coupe. Is that a replacement door seal or original on your car. If it is a replacement, how along did you order it and from which vendor?
Thanks,
CK
Old Nov 13, 2012 | 03:26 PM
7T1vette's Avatar
7T1vette
The "wrong" seal could have been packaged in the "right" bag. You should call the vendor and ask them to measure the total length of the coupe seal for you to compare with yours.
Old Nov 13, 2012 | 04:44 PM
Alan 71's Avatar
Alan 71
Hi ck,
The picture is of the original seal.
I haven't heard of there being a length problem with the seals you bought from CC.
The thing is, if you have a coupe you should have the longer seals because the convertible seals are shorter. So I'd think if you had the wrong seals they'd be short not long.
Any chance there are convertible doors on your car (it doesn't look like it in your picture)?
Regards,
Alan
Old Nov 13, 2012 | 05:42 PM
CoolKars's Avatar
CoolKars
Hi 7t1vette - I had vendor check, replacement seals are to their specs. Thanks. CK
Hi Alan,
My original fits exactly like yours in photo. Also your correct, I do not have convertible doors and if anything incorrect seal would be about 1 inch too short.
Thanks,
CK
To Outer Door Seals ?
