Trim Tag
Old Nov 14, 2012 | 12:46 AM
bellaireroad's Avatar
bellaireroad
Default Trim Tag
Does this trim tag look original? The car is black with black leather interior. It was repainted black about 20 years ago...this is the only photo I have until I inspect the car in two weeks. Thanks
Old Nov 14, 2012 | 01:23 AM
7T1vette's Avatar
7T1vette
I don't have info on the 'codes' to know that the colors are correct. But, the tag and rivets look to be original from that photo. If the codes don't match the actual colors of the car (ext. / int.), the paint and interior color may have been changed. (But, from what I can see, I don't think the tag has been altered or replaced.)
Old Nov 14, 2012 | 08:23 AM
Alan 71's Avatar
Alan 71
Hi ba,
There are people who are very knowledgable about Trim Tags in addition to Engine Pads and Engine and Vin Derivative stamps.
Depending on the car and it's documentation you might consider having a knowledgable person look at it.
Regards,
Alan
Old Nov 14, 2012 | 08:55 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by bellaireroad
...Does this trim tag look original?...
Looks okay to me. Black with black leather. Any reason to believe this tag would not be original?
I can't quite read the time/build code. H11?
Old Nov 14, 2012 | 10:27 AM
Mike Ward's Avatar
Mike Ward
There's no way of telling one way or the other with a fuzzy pic like that.
Old Nov 14, 2012 | 10:55 AM
joewill's Avatar
joewill
a 900 code with 402 black leather is probably the highest motivation out there to be faked.
the C2 trim tags actually have a methodology to sleuth their authenticity. The C3 tags are much less so and are much easier faked and can fool the greater number of people.
if you ( or your knowledgeable inspector ) look hard enough during your inspection you may find the original color under a bolt/bracket/plate/overspray etc...
hopefully, it is black.
www.trimtags.com
Old Nov 14, 2012 | 02:46 PM
bellaireroad
www.trimtags.com
that was my concern as well. I am retaining an expert to evaluate the car with me.
Old Nov 15, 2012 | 12:51 AM
jr9170's Avatar
jr9170
From: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
Looks real,but a clearer pic would help.
To Trim Tag
