High altitude carburation?
Old Mar 14, 2013 | 11:27 PM
TightFit's Avatar
TightFit
Default High altitude carburation?
Edit: I just realized I posted this in the wrong section. Moderators, if you'd like to move it, please do.
A little background: I just bought an 81 C3 that has a 383 with a Demon 650 cfm carb. The previous owner (John) bought it from a guy (Brian) in Kentucky and had the car shipped here. Brian built the 383 (in Kentucky...~1000 ft) and set it up with carb, big cam, ported alum. heads, headers, and dual exhaust. He then had the engine tuned on an engine dyno and it dynoed 407HP/439lb-ft (I have a hard copy of the dyno sheet...it's a beautiful smooth graph).
So, when John had it shipped here to northern NM (~5000 ft), he didn't adjust it for the altitude. Now, I've bought it and I live/work at 6500/7000 ft. It's powerful, but it doesn't feel anywhere near 407HP/439TQ. (For comparison, I've got a Trailblazer SS w/LS2 that has 410HP/420TQ at sea level and it MOOOVES...while weighing 1200 lbs more). There's always a gas smell after driving the car and it's only getting 10-11 mpg.
I've been reading that I need to have it rejetted for the higher altitude.
Can anyone give me some info on what size jets I'll need for this altitude? I've never done anything with a carbed engine before. I'm guessing that I'll need one of the biggest sizes, but I don't want to go too lean and blow up my engine.
thanks,
-Tim
Old Mar 14, 2013 | 11:44 PM
American Raven's Avatar
American Raven
C3 Corvette Enthusiast
The carb will have to be leaned at least. It's best to find somebody who is good with carb equipped cars to do the adjustments. Yes, you may have to have it rejetted.
I live @ 5000 feet elevation and had to rejet my Edelbrock 750 vacuum secondary carb to get optimal power and pass emissions. It was originally set for sea level operations.
Old Mar 15, 2013 | 04:15 AM
zuendler's Avatar
zuendler
Reduce transistion and main jet size by 2 numbers, and see what happens.
If your engine gets trouble running rich at this altitude, it was already very rich at sea level.
My engine was set at bit to rich at sea level, but head no problems at 7500ft. It was a bit weaker, but no gasoline smell.
If you want to make it perfect get a O² sensor.
Old Mar 15, 2013 | 12:16 PM
Mjolitor 68's Avatar
Mjolitor 68
How about strapping on a small supercharger ?
Forced induction is definately the ticket for altitude & hp
Old Mar 15, 2013 | 09:02 PM
TightFit's Avatar
TightFit
Thanks for the replies, guys.
Correct me if I'm wrong, but doesn't high altitude make a carb tuned for sea level become too rich? (not as much air)
Good solution...If only I could afford it.
Old Mar 15, 2013 | 09:24 PM
7T1vette's Avatar
7T1vette
From 1000 ft to 6000ft altitude, your engine will lose about 15% of its power (roughly 3% per 1000 feet of altitude change). So, that 407 hp engine would be putting out about 347 hp at 6000 ft. That's still a pretty good 'kick in the pants'.
If you didn't get to test the car out at 1000 ft, the only things that provide evidence of that engine's power are the seller's "story" and that "chart". I hope the power loss is due to the altitude change.
Old Mar 15, 2013 | 09:51 PM
TightFit's Avatar
TightFit
True, and the vehicle I'm comparing to (the 2008 Trailblazer SS) would similarly be down on power. It's rated 395HP/400TQ in stock form...which assumes sea level. I've modified it slightly to have about 15HP/20TQ more...again referring back to sea level. Those would be engine dyno numbers (i.e. not at the rear wheels) similar to the Vette's engine dyno numbers.
Don't misunderstand. I'm not really complaining about the power. It's definitely got more power than a stock 81. I just think there's a lot more in it and I'd also like to make sure it's running in top form so I'm not wasting gas, diluting my oil, and fouling plugs. Speaking of which, I haven't checked the plugs to see what story they tell, but I'll do that tomorrow.
Old Mar 15, 2013 | 10:02 PM
Shark Racer's Avatar
Shark Racer
Jets are measured orifices that allow fuel to pass through. Larger jets allow more fuel, so going smaller on the jets will lean it out.
As mentioned above, an altitude change will have a significant effect on seat of the pants as mentioned, but the "rule of thumb" above assumes equal AFR. Changing altitudes will also shift the car rich as the OP has mentioned.
Also, the number you got from the engine builder is likely on an engine dyno with shop headers, whereas your TB's numbers are going to be the actual installed power.
Good luck OP. Learn how to tune, it's worthwhile.
Lars has some good docs on tuning Holleys and QJets without a wideband.
Old Mar 15, 2013 | 10:16 PM
TightFit's Avatar
TightFit
Ohhhhhhh. (light bulb goes on!) That makes sense then. I don't know why but I had it in my head that the jets controlled the air flow.
Good to know. Since my car has headers going out to dual exhaust (no cats), I don't imagine there is a whole lot of loss there. The OP also eliminated the mechanical fan and replaced with dual electric fans.
Thanks for the advice. I would love to learn.
I've thought about going with fuel injection, but the FAST systems are gawd-awful expensive (looks like a minimum of ~$2500). For that, I'll learn to tune a carb.
Old Mar 16, 2013 | 12:40 AM
Shark Racer
Yup. I'd love to branch out from QJets and EFI and learn to tune Edelbrocks and Holleys, but there aren't many people in my local clubs running these things anymore...
A shop dyno will typically run an off-motor water pump, may not even run an alternator.
Old Mar 16, 2013 | 01:00 AM
Shark Racer
Take a look at this thread to see what a shop dyno setup looks like.
http://forums.corvetteforum.com/c3-g...run-today.html
Old Mar 16, 2013 | 01:33 AM
TightFit's Avatar
TightFit
Interesting. So the on car power will definitely be less. Have any idea what % less, generally speaking?
Very cool. His 357 has better HP number than my 383, and nearly the same TQ number.
Old Mar 16, 2013 | 02:38 AM
Shark Racer
It's really a crap shoot. I wouldn't worry about it a whole lot; fix the rich running problem and go have some fun.
Old Mar 16, 2013 | 07:49 AM
Matt Gruber's Avatar
Matt Gruber
what rpm is sluggish?
if it slow under 3000, then the intake manifold set-up is very important. see my article in profile sig for details.
Old Mar 16, 2013 | 11:04 AM
lars's Avatar
lars
I do a lot of dyno tuning up here at 5,000 in Denver, and I ship a lot of the engines I build to sea level. We're down almost 20% on power compared to sea level at this altitude, so don't be surprised at the power loss.
If the engine was correctly set up on the dyno at 1000 ft., you can drop jet sizes 2 numbers on both primary and secondary sides of the carb for your current elevation. This will restore the dyno-tuned air/fuel ratio numbers. You will also need to re-set the idle mixtures. This may give you back a little bit of throttle response, but it's not going to make a huge difference in power. What will gain you more is to bump the timing up a couple of degrees: You can run more total timing at high altitude, and this will give you a bigger power gain than the re-jetting. I just ran an engine on the dyno yesterday, set to a sea-level optimized 34 degrees total. Bumping the timing to 38 total gained 10 horsepower. I also tried 40, but the power did not change from the 38 setting, so I dropped it back down to the 38 total spec. If you have the dyno sheets, they should indicate what they set the timing to - add a few degrees to that number, drop your jetting by 2, and re-set idle mixtures. That will get you as optimized as you're going to get.
Lars
Old Mar 16, 2013 | 11:25 AM
deisenreich's Avatar
deisenreich
To echo Lars comments, I moved from Arlington, VA (sea level) to Santa Fe, NM (7000 feet) and felt a decent loss of power - approx 15 - 20 % on my 80 Vette with a Holley. Jetting helped a little, but bumping up the timing made the most discernible difference.
My neighbor has a 1971 camaro with a built 383 and his dyno is off significantly as well from previous lower altitude. He also bumped timing with no apparent ill effects. I am not an expert but it seems to help a bit and the altitude allows for more leeway absent detonation.
Old Mar 16, 2013 | 11:33 AM
REELAV8R's Avatar
REELAV8R
Lars beat me to it. Less compression requires lighting off the fuel earlier for best performance.
One more mod that will help is if the accelerator pump squirt is adjustable to reduce the fuel supplied by the pump. I'm not familiar with the demon 650, but on the q-jet it can be reduced by changing the point at which the linkage is connected.
I found that at altitude the accelerator pump shot is too much fuel making it rich on initial actuation of the throttle. No real affect at cruise rpm but makes a big difference when you stomp the throttle.
To High altitude carburation?
Old Mar 16, 2013 | 12:02 PM
TightFit's Avatar
TightFit
Wow! Great feedback! Thanks, guys! That give me a great place to start.
deisenreich, you're right in my back yard. I'm in Los Alamos, NM.
Old Mar 17, 2013 | 12:38 AM
TightFit's Avatar
TightFit
Some more info on my car: I measured the vacuum at idle and it's ~8.5 in. Hg.
I also measured the ignition timing at idle which is 16*. I noticed that the vacuum advance on the HEI is not hooked up (it's plugged). I'm thinking that may be robbing me of some part-throttle power (and some fuel economy).
Old Mar 17, 2013 | 11:42 AM
REELAV8R's Avatar
REELAV8R
At 8.5 inmg it sounds like the cam used has a pretty decent amount of overlap, good for ultimate power not so good for low end torque, especially at your altitude it may be a bit low.
Does it have the RPM intake? That one I believe has the cut down center divider and is designed to make power at high rpms. This will have a negative effect on your low end torque as well.
Matt Gruber has what seems to be a good helper for doggy low ends by using a 4 hole carb to intake gasket instead of the open hole gasket.
16* of initial advance sounds pretty good. You can try loosening it up and advancing or retarding it to see where the idle is the highest. Have you looked at the springs being used on the mech advance. they may be too strong and you might need to re curve the ignition for it to advance sooner. This means using weaker spring(s) to accomplish this. I'm guessing you can hook up the vacuum advance. If it starts to detonate at cruise with light throttle then get an adjustable vacuum can and back it off till deto stops or you may need to back off the initial a little. If you run into detonation with heavy acceleration then you'll know that the initial of 16* is too much or the mech advance is advancing too soon or too far and need to go back to a stronger spring.
I'm kinda glossing over the details here, go to the top of this page click on other then select tech tips, c3 and look for info on timing to get full details.
