Interior Heat
I also agree on the C6R style and I think I see the same front hood venting on the new C7 as well (correct me if I'm wrong!) and you're right, it would take some serious modding of the radiator angle, adding a splitter with two separate air paths, etc and whew, that's some serious work.
So we'll try this first and to 79CalShark, yes, I thought of finer or thinner gaps and I think that would look too, but I wanted to go a little 'beefy' structurally (more aluminum than holes) for the first iteration to see how it holds up. I will be painting them this weekend and hopefully mounting them by the end of next week, and then a testing we will go!
Of course, C3's are horribly unbalanced aerodynamically, so you probably can't make it worse
Though I guess it depends if you are trying to just vent air at highway speeds and low RPM/power for street purposes, or vent air and reduce front end aero lift at high RPM/power for race purposes.
You've got a good point!
It was a thought that crossed mind, because I thought I could utilize the laminar flow under the car, to go up and into the engine compartment at speed, but I can see what you mean, by the penalty at high speed and the drag effect is certainly something to think about.I think I'll stick to the ram-air, because that's relatively neutral (I hope) and from what I've see, the front of the vehicle at speed has a surplus of high pressure across the front and that forced into the intakes, I'm envisioning on the inside of the turn signals would work just as well, without the penalty of the 'scoops' and push air out of the engine compartment, from the front to the back.
I'd bet two two inch pipes, hard lines or tubes would have a pretty good amount of air coming through them at 65 mph! This is going to be the Phase II of the Thermal Management system I'm thinking of for the C3.
Phase I: Extract The Heat (Hood Vents or Grills)
Phase II: Keep it moving (Ram Air System from outer front grills to forward part of Fender Liners, behind radiator).
Phase III: Reflective and Insulation materials (multilayer technology, using reflective film and insulation to ward off what heat is left).
The last couple of times I was in a wind tunnel (a couple of years ago now) for an open wheel race car, we did several hundred runs just testing lots of little devices we thought would make improvement, device we'd designed ourselves, devices we'd seen on other cars where we had the theory behind it... of those several hundred runs, only a fraction made it on to our testing short list and only a handful actually made it on to the car
So often what you think a device will do, it doesn't do it as you thought it would, or it does it but then buggers up the flow somewhere else, and that's with a room of guys who have been doing race car aero for years
So treat any suggestions anyone makes as wild guesses regardless of how qualified they might be
And if anyone sounds confident that something will do something, assume they are too ignorant to know better
You could definitely mount a splitter, even a retractable one as you mention, down low which scoops are up in to the engine bay, but you need to make sure you have sufficient venting in the hood (not just "some" venting, but you need to make sure you can vent air as fast or faster than it wants to come in). If you don't, you'll end up with even more front end lift than the car had to begin with. My inclination would be to not try and scoop too much air behind the radiator though, as when you scoop air up behind the radiator rather than in front of it, you'll raise the pressure behind the radiator which will impede cooling.Of course, you won't know how much it'll impede cooling until you do it and test it. It may not even register on your temperature gauge... or it might... no real way of knowing without testing it (you could CAD up a model of the car and CFD it, but it'd probably be faster just to build something and test it
). I'm sure it won't impede cooling anymore than the tiny engine bay did to begin with and probably won't be a problem unless you're running at high RPM with your foot to the floor for long periods. Some of the C3's would overheat even out of the factory when you were pushing it. I've read some of the old magazine reviews of the LS5, complaining if you gunned it on the highway for any length of time it would overheat even when the car was new and not 40 years old.I'd bet two two inch pipes, hard lines or tubes would have a pretty good amount of air coming through them at 65 mph! This is going to be the Phase II of the Thermal Management system I'm thinking of for the C3.
I would be interested to see the air speed behind the radiator just in regular running as well, and what temperature it is. The electric fans on my radiator seem to pull a decent amount of air, if they had enough venting through the hood I'd hazard a guess at saying any ram air that I could get through a 2" pipe wouldn't make a lot of difference. But as always, the only way to find out is to do some testing.
LOL on the ram air experiment, by holding a pipe out of the window! Why, I might do, just that this weekend with some scrap 2" PVC pipe! And my thinking, is that the ram air would provide cold air directly into the engine compartment, versus the hot air coming out of the back of the radiator, and please correct me if I'm wrong here, as you have way more experience in this subject, than I do!
I will build and install square scoops behind the outer turn signal grills, that the two inch pipe will mate with. They would have a significantly larger cross section, than the two inch pipes they're mated to. I roughly estimate at least 4" tall, by 5" wide, with a four sided taper and into the two inch pipe(s).
Thanks again!
I also found my cold air intake had closed up from heat thru the years such that it wasn't really getting any air, so I put in a couple of spacers which opened this up a few inches which really helps scoop the cold air from the high pressure area right in front of the radiator...in pic just under hood with two wood dowels holding it open
, you can see in the 3rd pic looking down into the fan shroud, I have a dowel stuck
Down into the vent holding it open. I know the second owner recored the radiator
And there's an electric fan, which I didn't think was stock, so maybe he installed
It...not really sure when it opens but it only takes a slight push. I was guessing
It would open at high speed due to low pressure buildup as air flows under the car
But I just got the car a few weeks ago and haven't seen anything like it on the boards.
Anyone else have this bottom vent under the fan shroud? It's just above the front sway
Bar and behind the front cross member.
Or conversely, you could counterweight it, or make it driven against a counterwound flat spring, that would allow fold back, on deceleration and point straight back at speed. I'm just thinking aloud, here.
Again, I'm not a powertrain guy, but my understand is that it's an energy thing more than a temperature thing. So if the engine is dumping 5hp of heat in to the engine bay, it will still dump 5hp in to the engine bay regardless of whether you suck air through the radiator or whether you suck it through a cold air intake (the difference will be engine temperature will rise and more heat will radiate from the engine itself if you aren't sucking it through the radiator, but the heat dumped in to the air would be the same).
The amount of heat can obviously change depending on the engine and depending on the tune of the engine, but for a given engine and a given tune at a given RPM and power (like cruising down the highway), I can't imagine the waste heat changes much.
Sooooo, if you suck in 3000CFM per minute and vent it out, it will exit the car at the same temperature regardless of whether it was sucked in through the radiator or whether it was sucked in through a cold air intake (the difference will be engine temperature, not vented air temp).
That's not to say your ram air idea is bad, I guess I'm just saying that you need to think more about the total air coming through from the front of the car and whether your ram air intakes would increase that appreciably... I'm not going to advise on that unless I have some numbers so I can actually make an educated guess (I once tested radiators and fans in a wind tunnel for someone which would help... however I don't have those numbers on hand).
The time that a cold air intake vent would really help vs. just sucking more air through the radiator, IMO, is if you were trying to reduce cabin temperature and you could get the vent to dump air on the firewall. That way, you are cooling a localised area rather than simply trying to cool the whole engine bay (the same applies to ducting aimed at cooling brakes, you're trying to cool a very local area).
BUT, if the ram air intake can appreciably increase the CFM of air through the engine bay, I agree that it will help reduce engine bay temps... I'm just not sure it will and can't really advise on it without some numbers to back it up (I can tell you what tests you need to do if you want, but I don't really have the time or equipment to do them on my own car
).I'm not really trying to push you one way or the other on your design and think you have the right idea, just offering my opinion on the physics of what is happening
If you can get the engine bay temps down, that will improve performance because the engine is sucking cooler air from the engine bay, in which case a cold air vent or simply increasing radiator flow and ensuring it has proper exhaust venting achieve the same result. If you can't get engine bay temps down but just suck cold air straight in to the engine's intake, bypassing the engine bay as a whole, you'll improve performance as well (won't improve cabin temps, though).
That's kind of what I was implying with localised cooling vs overall engine bay temps. Cold air vents work for localised cooling, but if you're simply trying to bring the whole engine bay temp down (to simultaneously improve performance, reduce cabin temps and reduce wear on components that are being cooked in the engine bay) then your goal should be net inflow and net outflow. Then if you're trying to reduce front end lift as well for race purposes, you also need to make sure you aren't increasing pressure in the engine bay by ramming more air in to it than can be easily vented. It's a pretty complicated system of heating/cooling/air flow/air forces, hence why the race team that can spend 1 million dollars on improving aerodynamics is a lot better off than the team that can only afford $100k.
EDIT: edited for clarity.
Also, am I correct, Hagis, that an axial fan is more jet turbine like? That would make it easy to install, in-line and part of the ducting, itself?
A lot of really great thinking by everyone here and the last round of thoughts by,Tudz, our resident Aero guy, gave us some great technical thinking and a peek into the highly turbulent world of Aerodynamics! Thanks, both of you, for your contribution!
John
Tomorrow, we cut the hood. We also decided to paint the aluminum vents, satin black. The body color idea won't be as distinct, as it will blend and may not show up satisfactorily in pictures. Also, if this works, I want our prototype work, visible, but don't want to go the bright shiny route either.
With luck, I'll be testing this tomorrow. Must go home now!
That 5" width is the max! You're going to be chewing a whole lot of critical structure, going beyond that. S Also, the hood latches, on the underside, push the first available space, a full 12" plus, from the rear edge of the hood.
Gotta help John, surgery is happening soon, we put a lot of thinking, studying and all of you, contributed mightily to this thread. Thank you, to us, the C3 Corvette community! Will report on the patient, later on this afternoon.
