1979 Headlight Question
Old Sep 4, 2013 | 10:41 PM
Hideki's Avatar
Hideki
Default 1979 Headlight Question
I just recently bought a '79 and when I shut the engine off one of the headlights (passenger side) pops up. When I restart the engine it'll lower itself, and when I shut the engine off again it'll stay down. Anyone know if this is a simple enough thing to sort out?
Old Sep 4, 2013 | 11:11 PM
Aussie79's Avatar
Aussie79
It's a vacuum leak and almost certainly in your actuators, check all of your vacuum lines/joints and replace both actuators, not very expensive and easy to do.
Old Sep 5, 2013 | 09:16 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check/replace the white plastic filter in the main vacuum supply line first.
Old Sep 5, 2013 | 11:04 PM
Hideki's Avatar
Hideki
Thank you both for the info, I will try that filter change first (seems much less expensive ). Does anyone have a picture of what/where that filter is?
Old Sep 6, 2013 | 12:18 PM
7T1vette's Avatar
7T1vette
Most likely a bad actuator or vacuum relay for the right-side headlamp. And I'm leaning toward the actuator can (or the seal inside it).
Old Sep 6, 2013 | 01:26 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by Hideki
... Does anyone have a picture of what/where that filter is?...
In the main vacuum supply hose running from the intake manifold fitting. Follow the hose along and you'll see it.
Old Sep 23, 2013 | 11:32 PM
Hideki's Avatar
Hideki
So when I check my vacuum lines I notice mine is oriented different than any I've seen (the line coming off the PB booster). Would being oriented on its side affect anything? I am contemplating just cutting the existing hoses to make the thing sit correctly, but that metal hard line appears closer to the carb than the pictures I've seen so I don't necessarily want that thing in the way... Any advice?
Old Sep 25, 2013 | 01:27 PM
Easy Mike's Avatar
Easy Mike
...Any advice?...
My advice is not to cut power brake lines.
Old Sep 25, 2013 | 04:46 PM
Vette-kid's Avatar
Vette-kid
...go electric...
To 1979 Headlight Question
