Doorgunner's '68 Convertible Project
Old Oct 22, 2015 | 04:35 PM
  #2141
Calo69's Avatar
Calo69
St. Jude Donor '15-'16, '18
Originally Posted by doorgunner
Congratulations.....you just posted the 3 words that will have the FBI/CIA/DHS reading EVERY word that we post for the next 100 years!
As a combat veteran and defender of my Nation all I can say is...........
This should be fun
On a sidenote.......I'm making the fiberglass panels to hold the "suitcases and tent" as we speak
Gunner, you've been on every govt. watchlist since 1972, nothing new here.
Good to see the steady progress. Stay healthy.
Old Oct 22, 2015 | 07:07 PM
  #2142
loup68's Avatar
loup68
Army
Doorgunner, I think that Mid America would help you out with the extra long carpeting. Lou.
Old Oct 22, 2015 | 08:55 PM
  #2143
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Yeah, but where you gonna get fitted carpet?
I was wondering the same thing!
Originally Posted by Jack605
If anyone can do it DoorGunner can.
(No Pressure)
Jack
JUST GREAT! You've seen my 201 File also?
Thanks Lou......you were reading my and Derek's minds.
So.....I managed to keep the 1-2 hour-per-day Rule even with all the errands thrown in............
I made one side-extension for the cargo area before road-running, and started the other panel upon returning home tonight.
Maybe tomorrow I will be able to make the cargo floor panel
And yes......my grand-daughter is now part of Corvette history....the only available large-enough/flat-enough/non-stick surface was the lid from a storage bin...the outline of the panel shows perfectly for trimming...........
naturally the resin absorbed the permanent marker writing with no problem also!
108100
Old Oct 22, 2015 | 10:15 PM
  #2144
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
DG! You are making some serious progress! Great job doing the chopping of the fiberglass. Very bold, I am impressed, Sir!
Old Oct 22, 2015 | 10:48 PM
  #2145
doorgunner's Avatar
doorgunner
Thanks NAVY08........
that reminds me that I need to visit the garage and check the second panel to see if it is beginning to harden.
Old Oct 23, 2015 | 01:33 PM
  #2146
doorgunner's Avatar
doorgunner
Remember......I'm a Rookie at fiberglass work...don't use my "method"......LOL!
I actually did more panel-making this morning (after getting the family car inspected/tires balanced).......
I bought one of those fluorescent light diffuser panels to use as a surface to make the large cargo floor extension 36" wide by 15" deep/then used a marker to lay out the pattern.......
The same pattern was drawn on the fiberglass cloth........
I put a full size piece of cloth as the base layer/then used four edge-remnants of cloth to lay the next layer/alternating layers of full size and remnant cloth and coating the entire area with resin between layers......finally I added the full size 4th layer to finish the thickness....the panel isn't quite as thick as the original trunk floor because I used woven cloth for more support........Because of the extra floor length I will also add metal support braces under/across the floor.......
I'll give it an hour to firm-up......then trim the edges of all three pieces to rough-size for fitting onto the body.
NOTICE: DO NOT USE FLUORESCENT LIGHT PANELS....THEY DO NOT LET GO OF THE CURED FIBERGLASS!
Old Oct 23, 2015 | 06:01 PM
  #2147
derekderek's Avatar
derekderek
you also found the best way to get good at fiberglass work before you started attaching things to that body...
Old Oct 23, 2015 | 06:08 PM
  #2148
doorgunner's Avatar
doorgunner
I trimmed the edges of the new panels to rough-size, but had a problem removing the drip-tray/it REFUSED to "de-bond" from the original rear panel---so I had to cut off the entire upper part of the rear trunk panel/I will make a patch-panel to fill the void.........
This is the amount gained by removing the tank and extending the walls and floor.......3 feet wide by 15" deep.......
I'll try to install the panels tomorrow
Old Oct 23, 2015 | 07:57 PM
  #2149
SB64's Avatar
SB64
Tony are you using some kind of releasing agent to remove the fiberglass. I used Turtle wax heavy 3 coats and then laid my mat and resin. Just saying!!!
R
Old Oct 23, 2015 | 08:55 PM
  #2150
doorgunner's Avatar
doorgunner
R
R........the smaller panels release with no problem when I laid them on the large Tupperware lid......
BUT.....I got the bright idea to use a bigger ceiling-light-diffuser---it FELT like PVC based material--but it apparently had more "plastic" in it, causing the resin to bond to it
No big deal....I'll use the large Tupperware lid for the rest of the fiberglass work.
I did a little mocking up and measuring.....it's not "pretty", but now I have a good idea of the panel trimming that I will need to do.
This is a pic from the passenger side looking into the trunk/cargo area.
At the far end of the tape is where the original rear tank wall will soon fit..............
This is the original depth from the panel behind the seats...... 30" ......
This is the modified depth with the tank wall removed and the fiberglass extensions in place......... 45".................
Here is the original tank wall mocked up and resting against the frame rear crossbar.................
I wish that drip-pan would have come aloose with the heat gun/it would have fit much better in the new location, but it wouldn't budge after 45 minutes.....so I "wacked" the drip pan with a 6" cut-off disc.
Old Oct 23, 2015 | 10:36 PM
  #2151
briankeery's Avatar
briankeery
All this and you still won't cut out the deck lid?
Old Oct 23, 2015 | 10:51 PM
  #2152
doorgunner's Avatar
doorgunner
Yeahaa......Well......
While I was under the deck/inside the compartment....I glanced up.....
and thought..........
While I'm here...............
I'll call Sigforty to see if he will let me take some pics and measurements of his car with the deck lid up so I'll know where to make the "incisions"......
Happy now?
Old Oct 23, 2015 | 10:55 PM
  #2153
briankeery's Avatar
briankeery
Ecstatic.........and the Blue Jays have just tied it.
Old Oct 23, 2015 | 11:02 PM
  #2154
doorgunner's Avatar
doorgunner
"My work in this Galaxy is done".
Old Oct 24, 2015 | 05:59 AM
  #2155
SB64's Avatar
SB64
Default vette
Tony, I think you got it! Looks like you are doing an off body restore while keeping the body on the frame. I think between the 2 of us we might have been able to get a job with GM back in the 60's. We may have been just cleaning floors but who knows. Keep up the good creative work.
R
Old Oct 24, 2015 | 06:26 AM
  #2156
army's Avatar
army
Doorgunner.. this is the most interesting C3 thread I've seen in a while. I have no idea where you're going to end up with that project but like they say, the point of the journey is the journey itself.
Old Oct 24, 2015 | 08:05 AM
  #2157
derekderek's Avatar
derekderek
Happy now?
you can't just look up and stick sawzall right into the gap between hatch and deck?
To Doorgunner's '68 Convertible Project
Old Oct 24, 2015 | 09:15 AM
  #2158
doorgunner's Avatar
doorgunner
R
"Anybody can do it the right way......Only the O.C.D. and P.T.S.D. can do it O.U.R. way!"
(I still wish the car had not been molested, but I'll make the best of it being a Rookie)
Why.......thanks.......and me either......LOL!
You gotta remember....
I'ma rookie.....I need a visual aid to see what I'm doing
Old Oct 24, 2015 | 09:20 AM
  #2159
doorgunner's Avatar
doorgunner
WAIT A MINUTE!
"Interesting"................as in
OR
"Interesting"..................as in...................................... .
(never mind................I forgot to take my meds this morning)
Old Oct 24, 2015 | 09:48 AM
  #2160
derekderek's Avatar
derekderek
Or interesting as in "May you live in interesting times." Which is actually an old chinese curse. Cuz let's face it...you are never bored in a train wreck. and thanks. now i have paypal money. it is like play money. you never actually see it so it is easy to spend on stuff the spousal unit would complain about...like vette parts!!
