Doorgunner's '68 Convertible Project
Old Feb 27, 2014 | 08:55 PM
  #221
BOSTONCAMARO's Avatar
BOSTONCAMARO
looking good!!!
Old Feb 27, 2014 | 11:04 PM
  #222
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Originally Posted by croaker
I can't really tell by your pic's of your half shafts,you do know you should use french locks or something along those lines.If you knew that all ready forget I said anything.
Thanks,
I used hardened lock washers....they really bite when the bolt is torqued/in case they loosen, the French locks are next.
******************EDIT:***************** ** LOOKING BACK...I SHOULD HAVE PLACED ALL 4 ROTORS ON JACK STANDS TO IMITATE THE CAR SITTIN
ON WHEELS ON THE CONCRETE !!!
I yanked on my bootstraps and made it to the garage (PTSD sucks!)...After the problems that I had with the differential and half-shafts being off-center, I was really concerned about how badly the trailing arms would be out of tolerance/Mike Ward gave me some good advice on what to look for when checking/setting the toe on the arms...
I did a preliminary check on the camber and toe on the driver's wheel. First I supported the car on the rotors/then I leveled the differential crossmember (pay no attention to those greasy chrome Harley Davidson mufflers mounted under the differential....LOL)........
Then I adjusted the camber to +1 degree since the tires weren't ready to be installed yet......
Next I set up a string from front to rear to check the toe.....
Checking 13" (half the diameter of the wheel) forward of the spindle with dial calipers.....The string showed .090" toe-in Which would be .180" total for both wheels---which is too much---but close enough until the wheels are mounted...(that was a relief considering the toe could be off as much as 3/8" to 7/16"......
Tomorrow I'll try to get the wheels ready and mount them so I can set the camber & toe on the passenger's side, now that I have a good driver's side reference to measure from. Maybe this weekend it will actually be safe to drive around the block!
OOOOPS.....I noticed on the 2nd to last pic, I still need to install the new seat covers and mount the seats to the floorboard.....steering wheel too (the horn contact kit should be delivered tomorrow)
Old Mar 1, 2014 | 10:56 PM
  #223
doorgunner's Avatar
doorgunner
I managed to do a little more before we ran errands in town...the driver's and passenger's side wheels got a good degreasing/sanding outboard and inboard areas/satin-black paint to help the chrome stand out (since 1968, I never did like the green-tinted wheel paint)........
I really didn't care for the extra wide rear tires, but they're too new/too much rubber left on them to replace them (please ignore that hybrid '78 bumper clip---I already have a '68 tail-light clip to replace it!)....
The driver's side suspension passed another test....at the spring's lowest point there was still 1/2" of clearance between the end of the main spring and the inner rim lip on the 8" wide '69 rims......
Next.....install the passengers side wheel and check the clearance....When I received the car the end of the main spring was actually rubbing the inboard wall of the tire when the car turned right into curbed parking lots. This step should be ver-r-ry interesting to see how the clearance works out.
Old Mar 5, 2014 | 10:38 AM
  #224
doorgunner's Avatar
doorgunner
I couldn't stand the suspense so I did a trial-fit of the passenger's 8" rim/295 tire, so I shimmed the passenger's side trailing arm last night and temp. installed the wheel.
For a reference: It took (2) 1/4" shims and (1) 1/16" shim.....exactly the same amount as the driver's side trailing arm to remove the side-play on the pivot bolt.
(.562" shim-pack for each arm placed on the inboard side of each arm......which will be changed slightly to get the correct toe on both wheels once the car is off the jack stands and driven around the neighborhood a few times)
The end of the passenger's main leaf had 7/16" clearance from the rim lip while on jackstands---the driver's side had 1/2" clearance.....close enough!
WHEW! I'm glad that worked out well for a rookie!
I'll try to post pics tonight in this same reply as I install shock, wheel, and measure toe.
EDIT: The part arrived...the right-side is complete....the rear wheels are on the concrete after 6 months (of a one-month project... )
Note to myself: Finish torquing the (4) leaf spring mounting bolts tonight, now that weight is on the spring assembly.
Then post pics.
RE-EDIT: Sorry about not posting pics....I just got home from visiting my F.I.L. at the hospital.
Old Mar 6, 2014 | 03:36 PM
  #225
SB64's Avatar
SB64
Default restore job
Hey Doorgunner, where do you get that fancy dial indicator that you used for rear work that you are showing. High teck baby. The string idea is pretty cool to.
Old Mar 6, 2014 | 05:02 PM
  #226
doorgunner's Avatar
doorgunner
LOL.....the indicator is 30 years old......the string was used to build my fence behind our house.
Old Mar 6, 2014 | 09:47 PM
  #227
briankeery's Avatar
briankeery
Let's see that ride height now she's on the ground Gunner.
Old Mar 6, 2014 | 10:02 PM
  #228
The13Bats's Avatar
The13Bats
..... o 0 O ( Ummhum...looks like his will be driving way before mine is.....)
Old Mar 7, 2014 | 12:43 AM
  #229
doorgunner's Avatar
doorgunner
The last few days we've been spending time at the hospital with my father-in-law.
I hoping to have the front tires cleaned/painted/mounted with pics tomorrow night.
Well.....the wheels are cleaned/painted.....but not installed........
Another trip to the hospital and returned home too late to accomplish much.....maybe tomorrow....
Old Mar 7, 2014 | 01:19 AM
  #230
persuader's Avatar
persuader
Looks like we both are building our own version of a C-3 Frankenvette. Cool way to do a wheel alignment by the way. I hadn't seen the string method used in years. Did it myself one or twice back in the day. Gets you really close.
Old Mar 7, 2014 | 09:50 AM
  #231
doorgunner's Avatar
doorgunner
Sure does....this SBC 700R4 has about 30,000 miles on the "strings"...(don't worry about the trash can blowing away/it's frozen to the driveway...LOL)
Old Mar 8, 2014 | 05:29 PM
  #232
doorgunner's Avatar
doorgunner
O.K.........BUT BRACE YOURSELF ....annnnd yes---that's A/T fluid on the concrete from one of the rubber hoses that goes to the aftermarket trans-fluid cooler in front of the radiator
Bats............Maybe/maybe not........
Rookie-Me only "snugged-down" the camber adjusting bolts.....guess what happened the first time that I put it in Drive and gave it some "pedal"............
That would be a correct answer.......the rear suspension squatted down.........those big fat rear tires bowed out about 2" on the concrete.
Ohhh well........at least I stayed in the driveway!
So......back to the garage to replace the trans-cooler hoses (no biggie)....................annnnnnnnnnd. ....................."adjust the camber" again...with a torque wrench this time!
W-H-Y would someone do that to the body of a '68!?!?!?!?!?!?
Old Mar 9, 2014 | 10:20 AM
  #233
croaker's Avatar
croaker
The Vette kicked your Truck out the garage. Maybe you should put the caption Rescue Me by the Trucks picture
Old Mar 9, 2014 | 10:24 AM
  #234
doorgunner's Avatar
doorgunner
They talked it over........they will each take the garage a week at a time.
Old Mar 9, 2014 | 11:27 AM
  #235
1977L48's Avatar
1977L48
that's very grown up of them, lol
Old Mar 9, 2014 | 09:59 PM
  #236
croaker's Avatar
croaker
What's the story on those two pipes attached to your spring.
Old Mar 9, 2014 | 10:55 PM
  #237
doorgunner's Avatar
doorgunner
Here's the story.....brace yourself....(I'm trying to bring the body back to '68 appearance as the project progresses)
The 2nd owner decided to "update the car"--he removed the original front and rear clips/installed late '70s clips (no exhaust openings in the rear lower valance).
The 3rd owner began working on the car and cut the exhaust pipes off before the differential because they were rusted-out behind the diff. all the way to the mufflers.
Until I decide on side-pipes or mufflers, I have installed two spare chrome Harley Davidson mufflers to quiet the dual exhausts pipes down.
In the meantime,I recently bought a rear clip ('68 tail-light panel).....until I swap out the rear sections and make my exhaust decision, I will leave the Harley mufflers under the car.
And......Rookie-Me found why the camber went out of adjustment while test-driving the car after re-building the suspension....I didn't realize that I needed four of these.......
Strut Rod Bushing Caps
I see they have a bolt shoulder to center the bolt and take up slack....they also "bite" to prevent them from slipping when everything is adjusted and torqued down.
To Doorgunner's '68 Convertible Project
Old Mar 10, 2014 | 04:25 PM
  #238
doorgunner's Avatar
doorgunner
There.....and I thought that I would just reassemble the rear suspension with the original parts...
Too bad I didn't listen to the members and review the AIM to make sure all the original parts WHERE THERE IN THE FIRST PLACE!
I'm just glad I didn't destroy anything learning that lesson.
Old Mar 10, 2014 | 04:29 PM
  #239
MrJlr's Avatar
MrJlr
It's still a long way from when you started
Old Mar 10, 2014 | 04:48 PM
  #240
F22's Avatar
F22
Good one! At least you found out about the 'snugging' before it was driving around! Regarding the a/t fluid don't ya hate it, when they do that? It's almost like they've got to mark their spot, somehow! (like mine did, in my ex-wife's perfect-clean white driveway...)
