Doorgunner's '68 Convertible Project
Old Nov 24, 2014 | 10:09 AM
  #721
AirborneSilva's Avatar
AirborneSilva
Originally Posted by doorgunner
It could happen to ANYONE........(or just me)........
What happened was.....
I remembered 1960fi's location from his Avatar/While I was in Houston, I remembered a seeing a "Spring Branch Road"/I pulled up a map of Houston and located Spring Branch.......
the rest is.................................LOL.. .... .......history!
That is why I never go any farther than my leash will reach
Well since you go by DoorGunner I am going to assume that you were not infantry but sat in a huey door with an M60 so I guess we can forgive not being good at reading maps
Old Nov 24, 2014 | 10:22 AM
  #722
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Ohhhhhhhhhhhhhhhhhhhh.......here we go......"Mine is bigger than yours!"
No.........I was a doorgunner on a Chinook (affectionately know as a "Flying Coffin")......I didn't want to be a Grunt who got shot at all the time (little did I know )
I was assigned as a helicopter mechanic.....some paperwork "got messed up"......instead of a toolbox, the Supply Sergeant handed me a ........................................ ........................
machine gun........
it went downnnnnnnnnnnnnnnnnnnhill from there.
Old Nov 24, 2014 | 10:23 AM
  #723
doorgunner's Avatar
doorgunner
RATS! I just hijacked my own thread..............
37300
Old Nov 24, 2014 | 10:35 AM
  #724
SDS Photography's Avatar
SDS Photography
machine gun........
Wow, that is a pretty serious "paper mix up"
Old Nov 24, 2014 | 10:39 AM
  #725
doorgunner's Avatar
doorgunner
You have to realize.........We're talking "Arrrrrrrr-meeeeee"......(if you had more than 100 brain cells-----they sent you next door and made you a pilot in the Air Force......less than 100/Marine)!
Old Nov 24, 2014 | 10:48 AM
  #726
SDS Photography
Hahaha 10-4
Old Nov 24, 2014 | 10:53 AM
  #727
AirborneSilva
machine gun........
No no, none of that mine is bigger than yours stuff, just I know how to read a map and hump a ruck stuff
Never road in or jumped out of a Chinook, had friends whom did, but I took off in a few Huey's, just didn't land with them
Here's how dumb I was at age 19, I went into the recruiters office (this was at the the time of the fall of Saigon), told the recruiter I wanted to be in Special Forces, he says ok you gotta jump out of air planes, I said no problem, but you can't sign up directly for SF so we'll assign you to the 82nd but you'll never make it there since after you graduate jump school they will be asking for volunteers for SF before you get on the bus for Ft. Bragg, long story short (yeah too late), there was no one to meet me at the bus asking for volunteers for SF. I did my career in the 82nd, which I'm very proud of
Old Nov 24, 2014 | 11:05 AM
  #728
doorgunner's Avatar
doorgunner
What the......................!?!?
Saigon FELL? Nobody told ME!
***KING Politicians!
I hope I didn't missspeel ***KING.
Old Nov 24, 2014 | 11:32 AM
  #729
AirborneSilva
***KING Politicians
Oh damn, the cats out of the bag now
Old Nov 24, 2014 | 10:07 PM
  #730
TileArt's Avatar
TileArt
Hey!
Old Nov 24, 2014 | 11:09 PM
  #731
doorgunner's Avatar
doorgunner
Originally Posted by TileArt
Hey!
I was just kidding......we all know that the Army wouldn't have been needed in Viet Nam if the ****ing Politicians would have given you guys enough ammunition and M&Ms!
19 year-olds need their M&Ms!!!!!
Old Nov 24, 2014 | 11:41 PM
  #732
doorgunner's Avatar
doorgunner
On a sidenote........the top radiator hose no longer gets too stiff to squeeze....(while I had the cooling system apart, I replaced the top hose because of the overheating)....apparently, like you guys thought, the radiator was partially blocked causing the coolant to build up too much pressure.
I did what you guys recommended and replaced the original radiator with a temporary 1" aluminum radiator. I temporarily tie-wrapped everything in place to test the set-up and see if it would solve my problem(s) before I bought brackets to permanently mount the "new to me" radiator......
It really goes well with Bubba's 1" angle-iron radiator support......!
Rats......the gun reading didn't show-----it should read 195* before the thermostat opened.......
Annnnnnnnd 180* after the thermostat opened.......
I won't wrap the wiring or touch up the ductwork with satin-black until I drive the car tomorrow and test the aluminum radiator....
Old Nov 25, 2014 | 09:36 AM
  #733
doorgunner's Avatar
doorgunner
Originally Posted by Brack c
Hoping this solves your overheating gremlins DG
Exactly! And as one Forum member said----Maybe I can do away with all the "plumbing/duct-work" once I solve the overheating problem.
(All that sheetmetal and piping certainly is u-g-l-y...but there was NOTHING there when I bought the car---experimentation time!)
I'm going to go for another one-hour test-drive before lunch....if the cooling system does well---I'll extend the test-drive to 2 hours.
O.K. Men.........................it worked! I drove the car for one hour in town and on the expressways-----NO overheating.........ANNNND I could actually squeeze the upper radiator hose without needing channel-grip pliers!
I continued driving for another hour on the freeways----50 to 70 mph----NO overheating!
The heat gun and dash temperature gauge both read 180* no matter how hard I drove the car. or no matter how many traffic lights that I encountered.
I now have a 50/50 coolant/water mixture and "water wetter" since there is no more boil-over.
Tomorrow I'll try to get some audio/video when I take the car along some of the country roads.
So.................thanks to everyone for the input
37600
Old Nov 25, 2014 | 07:19 PM
  #734
Mike21175's Avatar
Mike21175
37600
Fantastic! A blocked radiator at the lower half will do that for sure.
Now that you have found and tested the solution, time to make under the hood pretty again.
Mike
Old Nov 25, 2014 | 08:14 PM
  #735
SB64's Avatar
SB64
37600
Go DG GO!!!!!!
Old Nov 25, 2014 | 08:36 PM
  #736
Brack c's Avatar
Brack c
Great news DG !!!!
Old Nov 26, 2014 | 01:48 AM
  #737
doorgunner's Avatar
doorgunner
Thanks Men......I'm learning (the hard way!)
I'm not going to de-clutter the engine bay until I remove the body for some repairs this winter......
(LOL....winter in La. .....3 days in a row of 30*F followed by 3 weeks of 70* F and sunny skies/repeat until mid-April)
I'm still doing everything backwards so I can keep the car rolling to make sure all major problem-areas have been corrected.
By the way....I really need o disassemble the speedometer (AGAIN) and replace the odometer "drive-shaft").....bring the disassembled dash clock to have the main-spring replaced.
To Doorgunner's '68 Convertible Project
Old Nov 26, 2014 | 02:36 PM
  #738
doorgunner's Avatar
doorgunner
Another 2 hours of driving today and everything was COOL......literally...
no overheating...
The temperature under the gas pedal was 75*f (ambient temp was 70*)
The air cleaner temp was 80*F......(rather than the normal 150*F)
It looks like I can finish making support brackets for the center console/install the new seat belts/shoulder belt guides/ and install the door panels.
Old Nov 26, 2014 | 03:57 PM
  #739
F22's Avatar
F22
Woo-hoo indeed! Glad you got the underhood temps tamed. That's a tough one and you put some really original thinking into this!
Old Nov 26, 2014 | 07:45 PM
  #740
doorgunner's Avatar
doorgunner
Tell me about it......"original thinking"......
you wouldn't hurt my little feelings if you referred to it as "Bubba-on-steroids"
The floorboard temperature under the gas pedal previously was 130*F.
37900
