Doorgunner's '68 Convertible Project
Old Sep 2, 2015 | 05:46 PM
  #1721
SB64's Avatar
SB64
Originally Posted by doorgunner
Exactly!
Naturally.....there were more errands today....but I picked up more plumbing stuff on the way home.......then this happen in about two hours (No More Hot Fuel Lines!)..................
The regulator supply and return lines are installed......I had to angle the regulator down about 1/2" to clear the air plenum................
It's a close fit/about 1/8" gap b/twn the regulator and the plenum.....I'll put a 1/8" gasket under the plenum later.......
Tomorrow I'll finish running the return line to the gas tank, then run the pump, check the fuel pressure at the carb, adjust the regulator and go for a test drive.
Test Drive coming up!
ZIO
Old Sep 2, 2015 | 05:49 PM
  #1722
SB64's Avatar
SB64
Exactly!
Test drive coming up! May the force be with you. Go Tony Go!
ZIO
Old Sep 2, 2015 | 05:55 PM
  #1723
Calo69's Avatar
Calo69
St. Jude Donor '15-'16, '18
Test drive? Plans for existing tires? Just wondering.
Old Sep 2, 2015 | 06:04 PM
  #1724
doorgunner's Avatar
doorgunner
2026 Loser of the Year
ZIO
Yes fellow Members....................
Test Drive # 15 will happen tomorrow.....maybe I'll be able to go more than 50 miles/trouble-free!
Annnnnnnnnnnnnd.......the tires are new/maybe 300 miles on them.
  #1725
AirborneSilva's Avatar
AirborneSilva
Good job gunner
Old Sep 2, 2015 | 06:11 PM
  #1726
doorgunner's Avatar
doorgunner
Originally Posted by AirborneSilva
Good job gunner
I couldn't have done it without you guys keeping me on track!
Old Sep 2, 2015 | 08:40 PM
  #1727
Mike21175's Avatar
Mike21175
Loving the tutorial.
Time for a drive, I'll be there cheering you on!
Mike
Old Sep 2, 2015 | 08:57 PM
  #1728
doorgunner's Avatar
doorgunner
Mike
The original plan was to drive to Academy and buy a GoPro........but the fuel pump delayed that!
If the car behaves tomorrow I'll try to get a camera and post some video this weekend.
91200
Old Sep 3, 2015 | 09:37 PM
  #1729
doorgunner's Avatar
doorgunner
No test drive yet....I started the car today.....found one fuel leak---tightened the fitting and checked/re-set the timing now that the distributor is working correctly.
The regulator was set for max pressure/9psi which caused the car to run as though the choke had closed (the air plenum was removed...the choke was fully opened).
I adjusted the pressure down slowly and midway the engine idled smoothly.
It starts well now in about two engine revolutions cold or hot.....no more constant cranking with the accelerator to the floor.
There is visible fuel return inside the tank....all is well.
Old Sep 3, 2015 | 11:25 PM
  #1730
doorgunner's Avatar
doorgunner
Here are some carb/fuel line temperature pre-upgrade/post-upgrade:
98* ambient air temp in the garage/no air circulation....................
Fuel line on passenger frame rail................pre: 190*F post: N/A
Fuel line mod. on passenger firewall............post: 115*F (75* drop vs frame rail )
Fuel line at mech. pump.............................pre: 195*F post: N/A
Fuel line mod from firewall to regulator........post: 105*F
Fuel line mod. at carb inlet.......pre: 150*F post: 105* (45* drop)......I had to adjust air bleed screws on carb out 3/4 turn.
All these post temps. will drop approx. 5-10 degrees with the car parked and running outside on the driveway.
Remember.....I would never do these mods to an original car.
But this has been "fun"/educational for me seeing the changes take place.
Now......to get the jackstands from under it..................AGAIN!
Old Sep 4, 2015 | 09:26 AM
  #1731
Calo69's Avatar
Calo69
Gunner, those are impressive temp. differentials, fairly simple and economical, makes you wonder why it wasn't done in first place.
Now put a damn A/C unit in the garage so we can see a temp. diff. From 98 to at least 80 deg.
Good job, now hit the road.
Old Sep 4, 2015 | 11:20 AM
  #1732
doorgunner's Avatar
doorgunner
I guess it was the technology of the time and GM wasn't going to "fix anything that worked or cost more."
When you have to adjust the idle air screws 3/4 turn total each screw, you know the engine is liking the cooler fuel!!!!
The yard work is done......now to install that fuel pump relay (so I don't forget to unplug the fuel pump power wire when I park the car....I already have the fuse block maxxed out with two e-fan relays, electric x-tra loud air horns, security system relay, etc!
"Be back in a few hours".
Old Sep 4, 2015 | 10:59 PM
  #1733
doorgunner's Avatar
doorgunner
There were too many interruptions today......but I did completely wire the relay in and the pump is "key On" now.....
the car is STILL on jackstands though
Old Sep 5, 2015 | 05:52 AM
  #1734
SB64's Avatar
SB64
there were too many interruptions today......but i did completely wire the relay in and the pump is "key on" now.....
The car is still on jackstands though
getting closer!!
Old Sep 5, 2015 | 09:26 AM
  #1735
doorgunner's Avatar
doorgunner
getting closer!!
Y E P !
I'm taking it off the stands this morning and going for a drive.......
I hope!
91600
Old Sep 5, 2015 | 01:29 PM
  #1736
SB64's Avatar
SB64
Y E P !
I hope!
91600
ANNNNNDDDDDD WEEEEEE ALL WAIT!
Old Sep 5, 2015 | 02:28 PM
  #1737
Tom69's Avatar
Tom69
2018 C3 of Year Finalist
Dang...is he broken down or still out enjoying the ride?
To Doorgunner's '68 Convertible Project
Old Sep 5, 2015 | 02:31 PM
  #1738
briankeery's Avatar
briankeery
Hopefully into the second tank full.
Old Sep 5, 2015 | 02:33 PM
  #1739
havesometo's Avatar
havesometo
STILL WAAAIIIIIITTTTIIINNNGGGGG
Old Sep 5, 2015 | 03:34 PM
  #1740
Calo69's Avatar
Calo69
Check the local news stations.
