Doorgunner's '68 Convertible Project
Old May 16, 2017 | 12:03 AM
  #3721
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
How do you like the blast cabinet? I was looking at the same one.
good to see the vette back in doors
Old May 16, 2017 | 02:21 AM
  #3722
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Originally Posted by tokim
That's got to be a nice piece of mind, having it behind closed door/s.
True......I forgot to take the tarp off it since I'm so "used" to seeing it covered and outdoors
Thanks Navy. I haven't used it yet.....the new shop is still cluttered from the move....but I have used similar cabinets before.....the "chute" under the cabinet saves a lot of time when reloading sand into the hopper/pot.....and it'slarge enough to blast the differential housing/half shafts/etc.......by modifying it on the left wall--cutting a large round hole---covering the hole with a rubber gasket with slits for long parts/driveshaft/swaybars/tie-rods/etc. to protrude through.
Old May 16, 2017 | 02:26 AM
  #3723
CraigH's Avatar
CraigH
Have you thought about different media for the new cabinet.
Mine got wet so i took all the Garnet out in a hope it would dry out but i don't think the media will.
Not sure if to get Garnet again or something else.
Your using sand and seem to get good results.
Old May 16, 2017 | 02:35 AM
  #3724
doorgunner's Avatar
doorgunner
It takes an extra few minutes, but I always put the media in a 5 gallon bucket with a tight lid on it. When the sand gets damp/Louisiana humidity......I will leave a 100 watt light on overnight inside the cabinet to dry out the sand/media before putting it in the bucket. The light below dries out the media when place under a large METAL pan filled with the damp media
Old May 16, 2017 | 02:39 AM
  #3725
doorgunner's Avatar
doorgunner
A couple of these with 100 watt bulbs placed close under the metal pan will dry media overnight...they get very hot so keep paper/etc away from them....
Old May 16, 2017 | 06:27 AM
  #3726
CraigH's Avatar
CraigH
I actually have a couple of halogen flood lights that I could use.
May tip it out on a piece of board then hit it with the lights for a while.
Or heat from below in a metal baking pan
Good idea, thanks
Old May 16, 2017 | 10:28 AM
  #3727
chazde3's Avatar
chazde3
I have the same one, just an older model and it works well. It will work better once I hook up the 60g compressor and stop abusing the 30g one that I currently have.
Old May 16, 2017 | 10:18 PM
  #3728
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I have the same one. My hose clogged right at the gun for some reason when I first fired it up, after I got that cleared I didn't have a problem again. Now the compressor likes to blow my fuses, the capacitor doesnt have the guts to spin it over well anymore
Old May 17, 2017 | 10:05 PM
  #3729
doorgunner's Avatar
doorgunner
Time out for a River Report:
Ole' Man River is running one month ahead of schedule.......normally it isn't this high until mid-June!
The original riverbank is 13 feet under water, which is not a big deal.....yet.....
The restaurant balcony is normally 50 yards from the water........
The levee that protects everything east of the river is about Halfway under......no big deal........yet.....
I'll check the local elevation charts for the highest point near my home.......just in case.
Old May 17, 2017 | 10:32 PM
  #3730
wendellp601's Avatar
wendellp601
The river is expected to crest this weekend in Vicksburg.
I think I saw 41' crest predicted for Baton Rouge by the middle of next week.
Old May 17, 2017 | 10:57 PM
  #3731
doorgunner's Avatar
doorgunner
41' is good news. 51' is baaaaaaaaaaad News! At 51' a ship can create a swell that will wet the dirt road on top of the levee
Old May 18, 2017 | 05:02 AM
  #3732
SB64's Avatar
SB64
Default Water
Hard to believe the places you show are so close to water that could raise and wipe them out. Checking on the other items Tony and will PM you.
Stay well my friend! Oh, I really like the new media cabinet. It will serve you well and get a good work out I am sure.
RVZIO
Old May 18, 2017 | 11:46 PM
  #3733
doorgunner's Avatar
doorgunner
RVZIO
The restaurant is built on the river-side of the levee. But the engineers built the 1st floor one foot higher than the levee!
Thanks for remembering about my questions....I still have to finish the gas tank so I can drive the car to the painter.
Old May 21, 2017 | 10:04 PM
  #3734
doorgunner's Avatar
doorgunner
I was just viewing RVZIO's thread now that he has moved to his new home and has begun working on his project in his new shop.
I am finally getting situated in our new home and emptying the ret of the moving boxes out of my little shop.
I am starting to feel a little better......so I connected the battery charger and will reconnect the sidepipes tomorrow (God willing).....set up a temporary gas tank and start the engine after 6 months of storage.
Pics of course/maybe a short video
Old May 22, 2017 | 05:02 AM
  #3735
SB64's Avatar
SB64
Go for it DG it's really a boost and you can do it. Took me awhile to figure out the video but it is very rewarding. Also know what you mean about boxes and getting things set up. That's a thought process all in itself!
RVZIO
Old May 22, 2017 | 03:46 PM
  #3736
doorgunner's Avatar
doorgunner
RVZIO
I made the effort! First I installed the sidepipes/only one fixable dent on one heat shield.........
Next I had to rig up a way to get gas to the engine with my new electric fuel pump.....................
The engine cranked over about 15 times before I decided to connect the HEI wiring
RATS! I DON'T KNOW HOW TO UPLOAD THE VIDEO FROM MY LITTLE KODAK DIGITAL CAMERA.....
ADVICE NEEDED!
Old May 22, 2017 | 03:57 PM
  #3737
wendellp601
One could claim that was intentional in order to prime the oil pump.
To Doorgunner's '68 Convertible Project
Old May 22, 2017 | 08:00 PM
  #3738
Rescue Rogers
Good job DG!!!!!
Old May 22, 2017 | 08:53 PM
  #3739
doorgunner's Avatar
doorgunner
Yeah......I just remembered I needed to prime the oil pump
Good job DG!!!!!
Thanks R.R. Now to weld the pinholes in the gas tank I built.
Old May 22, 2017 | 09:21 PM
  #3740
doorgunner's Avatar
doorgunner
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid774.phot obucket.com%2Falbums%2Fyy30%2F72doorgunn er%2FVIDEOS%2F100_7413_zpsmyw6zdgr.mp4&t itle=">
Rats! Video still will not download!
