Doorgunner's '68 Convertible Project
Old Aug 22, 2025 | 07:59 PM
  #8141
stingrayiii67's Avatar
stingrayiii67
Since your doing fiberglass work, flare out the wheel wells! lol.
Old Aug 22, 2025 | 09:56 PM
  #8142
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Tony, I hope that big fire in Roseland isn't affecting your air quality... You have enough problems from breathing shi* back in 'Nam
Old Aug 23, 2025 | 10:55 PM
  #8143
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Im OK. .....(cough...wheeze....cough.....snort)
RE. RE. RE-measured everything. Still need to add about an inch to rear edge of fender.
Old Aug 24, 2025 | 12:56 AM
  #8144
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Was just in getting my Cardio nuclear testing done myself on Friday. And like you now wait for the results. Although I expect to hear early this coming week.
wishing you good luck on your test results.
Old Aug 24, 2025 | 09:12 AM
  #8145
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
MRI Toilets......thats a tough one.
Old Aug 24, 2025 | 11:38 AM
  #8146
Chazvettes's Avatar
Chazvettes
Default Filler
Originally Posted by righthanddrive
Are you going to have to add material on the fender to remove the gap ? It sure seems odd that it moved that much. Good luck, and may the sun shine for the next few days for you/
Ed
Originally Posted by doorgunner
BEE-fore...............
AFFFF-ter.......I had to move the entire fender 1" from the door panel forward gap to get stuff to line up....
Then the monsoon hit for an hour.........
The chopped uo driver fender fit correctly....GO FIGURE
Time to clean up.
. What kind of filler or you using and is your mat thick or basic like local parts store?
Old Aug 24, 2025 | 04:59 PM
  #8147
doorgunner's Avatar
doorgunner
I NOW buy from a paint/body shop supply store nearby...good stuff. The 2-part panel adhesive is the stuff they use on new Vettes. I think it is evercoat panel Filler they sell, also. I forget the brand.
I was using auotzone resin until I got a quart that wouldn't cure. I tried the cloth once but it left too much texture showing through after curing. If I run outof mat in an emergency I use A.Z. mat. The body shop mat seems 50% thicker.
I spilled a tablespoon of the good epoxy adhesive on the garage floor and left it there until the next day. I had to get a hammer and chisel to break it and remove it.
Today is a relax-day...toooo hot to repair any stress cracks in the other fender.
Old Aug 26, 2025 | 08:46 PM
  #8148
doorgunner's Avatar
doorgunner
After sanding all the old paint off I slapped the panels on to get themm off the driveway......
It got too hot in my dust suit so I hosed meself off and stretched the outdoor carpet onto the garage floor to let it flatten out after being folded up for 6 months....(turned on the garage a/c)......
NOW I need to clean out the back half of the garage and hang everything on pegboards already attached to the wall...the Harley is under the biggest lump of carpet.....
Old Aug 26, 2025 | 10:22 PM
  #8149
Barrist's Avatar
Barrist
Just damn glad to see your working again. Still waiting for the final results!
Have a Great Day,
Bill
Old Aug 26, 2025 | 10:49 PM
  #8150
doorgunner's Avatar
doorgunner
Bill...thanks...with the ptsd a weeks work is taking me 3 months...I' having to redo 50% of the repairs.
Bit it's all in fun.
Old Aug 26, 2025 | 10:57 PM
  #8151
litevette's Avatar
litevette
Looks like you’ll have a nice floor to crawl around on. More so now with the water dam.
Old Aug 27, 2025 | 08:41 PM
  #8152
doorgunner's Avatar
doorgunner
The dam worked well. No more carboard boxes floating around near the garage door.
I'm stilll moving junk so I can lay down more carpet...may as well get the tools picked up and things put where they belong....AGAIN.........
That's the Harley way back on the left side waiting it's turn to be reassembled.......
Center Line for lowering hardtop onto car...........I'm using 3/4" thick by 1" high Hardy-Board strips held in place with deck screw along the walls, but they're not easy to see. As the carpet settles I can loosen the strips and take the slack out of the carpet
The "Nose Camera" will help me center the car on the stripe. I'll need to add a cross-line to stop the car directly under the lifting hook that will hold the hardtop.
Old Aug 28, 2025 | 05:36 PM
  #8153
doorgunner's Avatar
doorgunner
I gettting the rear edge of the fender ready for a bonding strip that will add 1&1/4" to fender length...
pattern for boding strip traced with extra 1&1/4" added....
Poster board curved for taping to fender curve...
The blue painter's tape prevents the fiberglass resin from sticking to the poster board. The fender is pulled away from the body for taping purposes
Maybe I'll get the nerve to remove the fender and start laying layers of fiberglass later today?
Old Aug 28, 2025 | 07:57 PM
  #8154
OldCarBum's Avatar
OldCarBum
You’re a brave man Tony!
Old Aug 28, 2025 | 09:14 PM
  #8155
doorgunner's Avatar
doorgunner
The V.A. calls it Brain Trauma = Getting one's self in a bigger jam(b) while trying to get one's self out of a smaller jamb.
FOR EXAMPLE: the pattern is clamped in place...the bonding strip is being built up in stages.....
The inside of the fender...UGLY but it will be stout after more bonding layers are laid tomorrow.....I'll remove the clamps and sand the area so more layers can be added....
Old Aug 29, 2025 | 10:38 AM
  #8156
doorgunner's Avatar
doorgunner
Bitch runs a stop sign broadsides me. Jumps out screaming that i hit her.
So why is your front bumper layinbg on the ground and the side. Of my truck is damaged IF I HIT YOU, LADY!?
LOO-Z-ANNA XRIVERS...I TELL YA"!
Old Aug 29, 2025 | 12:28 PM
  #8157
litevette's Avatar
litevette
Sheez! Sorry to hear it man. I had a lady do that 2 yrs ago. As she was running into me I could see clearly... her head was down and she had her cell phone in her hand. She was obviously oblivious to the stop sign. Hope the Tiktok video was worth it!
To Doorgunner's '68 Convertible Project
Old Aug 29, 2025 | 03:05 PM
  #8158
Rescue Rogers
Thats why i have cameras in all my cars now.....liberal drivers suck
Old Aug 29, 2025 | 04:07 PM
  #8159
doorgunner's Avatar
doorgunner
Thanks members...we brought our sisterinlaw to her chemo appt when the state trooper released us.
My wife said he stayed to interview the wo....errr...person who hit us.
By the time we got home 3 hrs later our insurance informed us she was suing for damages. well that did it for me...i told our agent i was a veteran and was mad about some idiot lying about an accident that was obviously the other driver's fault because of the type of damage done to both vehicles.
BUT...its a different world today as you know...right is wrong and wrong is right.
I'll hold off on the fender modification/my neck hurts and my brain is still reeling from the impact.
I had to grab the steering wheel so hard to keep from hitting cars on the left side of me that I broke open a cut on my thumb that was healing. by the time i pulled off the highway there was blood running down the steering wheel..I told my wife WHY IS THE STEERING WHEEL WET?/then i saw the blood dripping/
....i guess the old heart was pumping about 60 psi
I stayed seated in my truck and let my wife handle things...I didn't want to unload(verbally) on the bitch(no...i'm not sexist...she wasn't a bastard...I think)
Gotta' keep a sense of humor nowadays
Old Aug 29, 2025 | 05:22 PM
  #8160
OldCarBum's Avatar
OldCarBum
Tony,
Never go by what anyone states at the scene of the collision.
People say things that the evidence at the scene shows otherwise.
It usually takes a few days before the accident report is available to the public.
It should show a sketch of what the officer documented and his or her written statement of the events pursuant to the evidence.
There is usually a clear statement stating the party at fault.
Did you or your wife take pictures at the scene?
The other driver can call your insurance company and say or threaten all she wants, but they will not make any decisions until they get a copy of the officer’s report.
You have insurance and this is what you pay for.
You have nothing to worry about, you’re covered.
