Doorgunner's '68 Convertible Project
BY THE WAY.....the San Francisco murder suspect's photo LOOKS A-LOT LIKE THE SCUM who killed my son. I HAVE CALLED LOCAL, PARISH, AND STATE AUTHORITIES====I EVEN CALLED THE SAN FRANCISO HOMICIDE DEPARTMENT.......NO ONE HAS RETURNED MY CALLS IN THE LAST 36 HOURS.
Thanks for caring.
A very concerned detective called me last night from San Francisco....
My wife came home from a family trip and thought the S.F. scum looked a lot like our suspect......BUT she said he was much too short to be our suspect.
Now.....to get my mind cleared again (as much as possible
)82500
BUT.......
Goodbye old friend...................
ALL old weatherstrip has been removed from car.......
Bubba's grill-work will be replaced...........
with THESE.............................
The engine bay will be redone/the experimental CAI
will be upgraded to shiny stuff.....
With this simple/efficient/set-up that Addballer is using on his car.........
THIS will be replaced..........................
With THIS...................................
The top ........................................ ...............
has been refinished and is already collecting dust.........
And it ALL depends on the PTSD going on vacation so I can actually CONCENTRATE
How does that cold air intake work in the rain? I'd be afraid of sucking in a lot of water with it sitting in the wiper area like that. Looks really good though.
(I'm sticking with the easy stuff for now!)
it was a rough few months....111 days "shut down" so far this year
I'm doing "good" the last two weeks.....The V.A. uses the term "Base-line"........which basically means ......a bad day for the average person would be a GOOD day for a veteran.
(That's our Psych lesson for the week LOL)
I looked at her and said "The Delivery Service guy retired.....someone else will have to do it!"
Now she keeps asking me "How much longer before it gets painted?"
(Let's see.....replace tail light "clip"/replace front grill "clip"/replace modded fender gills/clean-repaint engine bay/replace body mount bushings/fiberglass-re-gap both door openings........hmmmmmmmmmmmm.......Sept ember------if the PTSD doesn't jerk me around!)
Ohhhhhhhhhhhhh Welllllllllllllllllllllllllll
It took a few minutes......but I finally got it!I removed the original firewall harness. The waterproof "grease" that the factory coated the inside of the connector with had dried up and was allowing rain/moisture to soak the terminals between the two halves of the fuse block.
Apparently I forgot to clean/inspect the firewall connector when I replaced the dash harness/fuse block
Back to the garage...............................
