Doorgunner's '68 Convertible Project
Old Oct 5, 2015 | 08:08 PM
  #1961
derekderek's Avatar
derekderek
Ok, that pic of the cut off rear. That is the rear bumper mount flange? Can you see the seam where that clip wae bonded to the 68 clip? You might wanna try to scare up ur borrow some clamps with a really long reach. Another cheater method. Get everything lined up and trimmed. Then get bonding strips bonded to the car. Then using tiny bolts, 8/32 or so, get the taillight panel attached and lined up. Then remove the bolts and goop it up with the correct adhesive and reattach the bolts to hold ot in the correct location and provide clamping effect. Way up high you might need to drill and put in a couple of pop rivets where you can't bolt or use a couple of sheet metal screws. Then when he is dry and hard amd in place, pull the screws and you have a couple of small holes to fill...
Old Oct 5, 2015 | 08:36 PM
  #1962
derekderek's Avatar
derekderek
Ok, i have a couple of flaws but all in all a decent mold.
Old Oct 5, 2015 | 08:43 PM
  #1963
derekderek's Avatar
derekderek
Meanwhile this part which is the definition of front and center came out real nice...
  #1964
doorgunner's Avatar
doorgunner
2026 Loser of the Year
No wonder I was having such a hard time cutting the '76 tail light clip off the body......I was ACCIDENTALLY splitting the bonding seam that the previous owner placed in that spot!
ROOKIES
Old Oct 5, 2015 | 08:51 PM
  #1965
Mike21175's Avatar
Mike21175
Originally Posted by doorgunner
No wonder I was having such a hard time cutting the '76 tail light clip off the body......I was ACCIDENTALLY splitting the bonding seam!
ROOKIES
I saw that too, but I figured you knew what you were doing and man, did you ever hit the mark on that one.
Mike
Old Oct 5, 2015 | 08:52 PM
  #1966
derekderek's Avatar
derekderek
File it under great minds think alike... you instinctively picked a disassemble line right where they put the assemble line.
Old Oct 5, 2015 | 09:00 PM
  #1967
derekderek's Avatar
derekderek
ok, i am out of rubber gloves and beer. time to put the mold back on the nose to cure overnight. then some trimming and waxing and start pulling a bumper lip tomorrow...BTW, johnsons paste wax is an excellent mold release agent.
Old Oct 5, 2015 | 09:16 PM
  #1968
doorgunner's Avatar
doorgunner
Mike
Originally Posted by oldgto
"ANYBODY can restore a car.... but it takes a REAL man to cut one up!"
TEAMWORK!
Old Oct 6, 2015 | 07:40 AM
  #1969
doorgunner's Avatar
doorgunner
The pulled muscle" on my right side kept me from the garage last night/no trimming was done on the rear fiberglass.
A couple Aleve should "kick in" soon though and it will be time to get the downward angle on the tail light panel adjusted.
Old Oct 6, 2015 | 08:28 AM
  #1970
derekderek's Avatar
derekderek
Ok, before you final cut, go back and get reference angles off the other car. That angle measurement is a plumb bob. Measures against gravity. If his ride height or body on frame height or even tire pressures are different from yours, the angle can be off a degree or 2. So i am thinking door sills, top of hatch, top of front doors. Both sides on both cars will tell you if you need to add or subtract a tiny bit to compensate. It could also tell you it is dead on, but that is a good thing to know too. Now we need more homework on the bonding strips. Do we use the front side or the back side of the old panel? What sanding grit provides the best surface to bond to? If front side, do we remove paint to bare glass? Or prep the existing surface?
Old Oct 6, 2015 | 08:55 AM
  #1971
doorgunner's Avatar
doorgunner
His body was on a wooden frame......the frame was level.
I need to measure from the garage floor to the bottom of the frame near the wheel wells and use jack stands under the front frame rails to level my car.
Then I will trim to get the 20* angle........
I will have to bond the front/top-side of the strip that I cut off the '76 deck and fenders onto the body since the strip contours completely from fender to fender.EDIT: AFTER READING DUB'S THREADS ABOUT BONDING....IT'S A BAD IDEA TO USE OLD FIBERGLASS SECTIONS AS BONDING STRIPS---THERE IS TOO MUCH CONTAMINATION ON THE FIBERGLASS, AND THE STRIPS ARE TOO UNEVEN TO GET A SMOOTH SEAM LATER!
Old Oct 6, 2015 | 09:29 AM
  #1972
derekderek's Avatar
derekderek
I think you want a much rougher grit for better bond. 36 i have heard. Let's find out for sure.
Old Oct 6, 2015 | 10:12 AM
  #1973
doorgunner's Avatar
doorgunner
There was a problem.....which turned out to be a benefit: The driver-side marker light was completely missing from the tail light clip......
BUT, it made positioning the clip a lot easier/I used a dremel with cut-off wheel to trim the ragged edges......and since the car is a resto-mod/the P.O. glassed over the front markers anyway.
Now the driver-side panel is set at 20*........
I did the same thing to the passenger-side of the tail light panel. Then I scribed a line into the paint along the edge of the tail light clip in order to cut the excess off the deck and fenders to prevent overlap bulges.
Now to double-check the scribe lines.....then cut the excess off.
Old Oct 6, 2015 | 11:09 AM
  #1974
loup68's Avatar
loup68
Army
Tony, just to clarify, the 68 date molded into the tail light lens is a date signifying that the lens complies to federal standards at that time. All 68-69 OEM lenses and replacement ones have the 68 cast into them. It is not a date code. Lou.
Old Oct 6, 2015 | 12:30 PM
  #1975
doorgunner's Avatar
doorgunner
Who would have thought.............
Thanks Lou!
Old Oct 6, 2015 | 02:06 PM
  #1976
doorgunner's Avatar
doorgunner
Modus Interuptus!
I'm back from running morning errands and managed to make the final cut across the deck and fenders for the tail light clip (other members who make this modification will need to determine WHERE THEIR CUT NEEDS TO BE MADE/I had to work with the damaged donor piece...so my cut is irregular and close to the gas tank).
The remaining extra deck length is cut off using a jigsaw/I slid 1" thick slats of wood between the top of the gas tank and the fiberglass deck to have clearance for the jigsaw blade........
Here is the deck waiting to have the tail light clip clamped in place in order to see how the bonding strips will be placed........
Old Oct 6, 2015 | 02:14 PM
  #1977
AirborneSilva's Avatar
AirborneSilva
Just a thought from one Tony to another, but why don't you drop the tank? It will make life easier for bonding the new piece in...
To Doorgunner's '68 Convertible Project
Old Oct 6, 2015 | 02:21 PM
  #1978
doorgunner's Avatar
doorgunner
Exactly! I dodged one by using the wooden slats with the jigsaw/I SHOULD have removed the tank first....but now I will HAVE to remove the tank to do a good bonding job on the deck underside before installing the tail light clip!
It's time to clamp that clip into place....will be back in a couple...................
Old Oct 6, 2015 | 04:20 PM
  #1979
doorgunner's Avatar
doorgunner
No problem.....I will get what I need tomorrow.
In the meantime I got a little more done on the clip fitment..............
The top of the clip is nice and flush with the deck all the way across......
The driver-side fender fits fflush but needs a little trimming for the bottom 4 inches to pop into place...............
The rear view (starting to really look like the title now {1968}........
Old Oct 6, 2015 | 04:25 PM
  #1980
derekderek's Avatar
derekderek
Now you can't even use that view in your avatar...unless you change rescue to past tense...
