Restoring console plate
Old Sep 22, 2013 | 08:56 PM
bellaireroad's Avatar
bellaireroad
Default Restoring console plate
The console plate has what looks like a silver paint on the fine trim. Has anyone tried to paint this or restore it? If so, could you share your experience and how it turned out? Thanks
Old Sep 22, 2013 | 09:31 PM
Lupigiato's Avatar
Lupigiato
There has been a number of threads on this topic that you can search. I've got them saved as I'll be freshening my painted interior surfaces this winter.
Old Sep 22, 2013 | 11:04 PM
Mike Ward's Avatar
Mike Ward
Original consoles are chrome plated zinc/pot metal. Paint the whole thing semi-gloss black then remove the overspray from the chrome. Not difficult.
Old Sep 23, 2013 | 06:40 AM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
I done mine like mike said come up great
Old Sep 23, 2013 | 07:15 AM
bkvette3's Avatar
bkvette3
Nicely done.
Old Sep 23, 2013 | 08:06 AM
Alan 71's Avatar
Alan 71
Hi bar,
If the chrome on the exposed detail areas is still in good condition you can generally have very good results as sug's example shows.
Some people put tape on the edges before painting and then pull it off.
I found that this sometimes leaves an exposed edge on the paint.
I use an x-acto blade to slice the paint off the chrome as soon as the paint flashes. It takes a little practice, but is actually pretty easy to do.
I believe the original paint used was semi-flat.
Regards,
Alan
Old Sep 23, 2013 | 09:02 PM
LemansBlue68's Avatar
LemansBlue68
Originally Posted by Alan 71
Hi bar,
Regards,
Alan
Exactly as Alan said. No need to tape off first, just use the Xacto knife. I find that SEM makes a semi-gloss interior trim paint that has the perfect sheen for pieces like this.
Old Sep 23, 2013 | 09:16 PM
Jim78SA's Avatar
Jim78SA
I will be doing a custom job on mine. I have a a 78 SA, so I decided to paint the trim dark silver, like the bottom color of my car. Then I will water jet out brushed aluminum inserts and rivet them into place, or glue them.
Old Sep 23, 2013 | 11:09 PM
bellaireroad
Thanks, I thought it was plastic, with silver painted on the trim edges
Old Sep 23, 2013 | 11:10 PM
bellaireroad
that looks really good
To Restoring console plate
