totally dumb question
Old Sep 25, 2013 | 08:52 AM
markyerger's Avatar
markyerger
From: You are here to build strength, not demonstrate it
St. Jude Donor '08
Default totally dumb question
Brace yourself.
my 71 has the Rallye wheels and raised white letters.
For some reason, I am reluctant to apply ArmorAll or some other tire foam.
I am afraid it will look cheesy
Now, my 2006 Subaru has blackwalls and I like to shine and gloss them up, but I am not sure on the 71's.
opinions???
anyone wanna tell me I need a life???
Old Sep 25, 2013 | 09:03 AM
Eljay's Avatar
Eljay
I have white letter BFGs on my 69 Pontiac and have found if you just spray over the letters with tire juice they start to get dirty looking. I use a tire sponge and spray the (I think it's Black Magic) on the sponge and go around the letters, as close as possible. Also Wesleys Bleach White is THE stuff to get the letters white.
Old Sep 25, 2013 | 09:19 AM
spot99's Avatar
spot99
If you wanna be real **** about the white lettering, use the Wesleys as per instructions and then hit the tire with your favorite dressing. THEN, using rubber gloves and a small rag, reapply the Wesleys to the raised lettering via the small rag.
Old Sep 25, 2013 | 09:34 AM
oldalaskaman's Avatar
oldalaskaman
or .. have a tire shop turn the white letters inside and make em as black and shiny as you like
Old Sep 25, 2013 | 09:35 AM
oldschoolvette's Avatar
oldschoolvette
This is a tough one...
Just put the stuff on the tires and clean the letters when done. It will look good
Old Sep 25, 2013 | 09:36 AM
1977L48's Avatar
1977L48
or just run with flat black tires like me, miles of not worring about tire stuff slinging off, and IMHO it fits my life better. raised white letters are the WTG tho!! really sets off the car
Old Sep 25, 2013 | 09:42 AM
MrJlr's Avatar
MrJlr
Can I have my click back ?
Old Sep 25, 2013 | 09:45 AM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Originally Posted by oldalaskaman
or .. Have a tire shop turn the white letters inside and make em as black and shiny as you like
bingo.
Old Sep 25, 2013 | 09:51 AM
Roco71's Avatar
Roco71
I use Westley's Bleche-White to clean and then dress them with Mothers VLP conditioner
Old Sep 25, 2013 | 02:38 PM
Alan 71's Avatar
Alan 71
Hi,
I use Wesleys on the letters and Eagle 1 Satin Tire Finish on the tires.
The satin makes the tires an even black without making them look wet.
Regards,
Alan
Old Sep 25, 2013 | 02:44 PM
ryanmh's Avatar
ryanmh
Need life.
Seriously, just put the Westleys on, scrub with a tire brush, rinse, wait to dry, and then a light coat of Armor All. Fast, easy, and works great.
Old Sep 25, 2013 | 06:10 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
Mark, how come I've never seen your car cruising down 202?
Old Sep 25, 2013 | 07:12 PM
jnealg's Avatar
jnealg
Shiny is good IMHO. I clean with comet and a brush, hose down, dry and armor all
Old Sep 25, 2013 | 07:30 PM
Try some Adam's V.R.T. On the tires. Not a high gloss look and doesn't sling off onto the side of the car.
Old Sep 25, 2013 | 07:39 PM
7T1vette's Avatar
7T1vette
I don't like 'protectants' that don't dry. For me, Armor-All is the "pits".
For interior plastic/vinyl parts, leather, and rubber (including tires and engine compartment hoses) I have used Nu-Vinyl for over 30 years. It is a water-based, polymer product and will dry quickly, leaving a clean satin finish that will last weeks. When applied to clean tires, it leaves the surface looking like new rubber. It also seals the surface so that it won't pick up dirt in the pores of the rubber. And, since it blocks UV rays, it will keep the rubber viable for longer life. It will not peel, flake-off, or yellow with time.
Mequiar's for plastics and other brands make polymer sealants/protectants. They should be used on rubber & plastics...NOT petroleum based products.
Old Sep 25, 2013 | 08:12 PM
markyerger's Avatar
markyerger
St. Jude Donor '08
I've had it only about 3 months
Old Sep 25, 2013 | 08:50 PM
Mooser's Avatar
Mooser
Another vote for Wesleys on white letters (hard to buy up here in )
I've been using 303 protectant for tires (dash etc) for years now. Nice satin black look with no greasy residue to attract dust or sling off the tires.
M
To totally dumb question
