How many running points and condenser
Old Oct 8, 2013 | 06:31 PM
OL'SKEWL's Avatar
OL'SKEWL
Default How many running points and condenser
I was just wondering how many of you guys are still running points and condenser? I have all numbers matching 72 and thinking about changing to pertronix ignition in my 350/200 hp car.
Old Oct 8, 2013 | 06:50 PM
Mike Ward's Avatar
Mike Ward
Me.
Old Oct 8, 2013 | 06:56 PM
Paul L's Avatar
Paul L
My 1974 struggles along very nicely with them. The Echlin sets at NAPA are (used to be) pretty good although people say they are now Chinese. The set I bought five years ago is A-OK still.
Old Oct 8, 2013 | 07:00 PM
Chuck72's Avatar
Chuck72
Old school for me, too.
Points, condenser, lobe lube, tach/dwell meter, flex Allen wrench,...bulletproof.
Always have, always will.
Old Oct 8, 2013 | 07:05 PM
frankturbo's Avatar
frankturbo
Me also
Old Oct 8, 2013 | 07:09 PM
Roco71's Avatar
Roco71
I am. I got my 71 with a aftermarket HEI unit and changed it back to a original points distributor.
Old Oct 8, 2013 | 07:21 PM
spjrr's Avatar
spjrr
Points here too. Am not convinced on electronic other than hei. Have had problems in the past with several brands of aftermarket electronic systems and most failed due to heat. If you do go electronic, carry a set of points and whatever else you need to put them in. Also on the aftermarket electronics if you are going down the highway and it cuts out then comes back on you may loose mufflers due to backfire. Have had that happen.
Mark Smith
Old Oct 8, 2013 | 07:22 PM
7T1vette's Avatar
7T1vette
Count me in. The car had a Pertronix installed when I bought it; had problems with spark miss, etc. and replaced it with [simple and reliable] points/condenser. I inspect and adjust them every year (also the distributor cap and rotor), change the condenser every two years [unless an unexpected ignition miss shows up earlier], and just "keep on cruisin' "...
Old Oct 8, 2013 | 07:33 PM
Paul L's Avatar
Paul L
Having said what I said, an OEM GM HEI is pretty dependable. The HEI units for $69.95 from China are....?
Old Oct 8, 2013 | 07:43 PM
Ironcross's Avatar
Ironcross
Seven out of nine are points including two with dual points
Old Oct 8, 2013 | 07:49 PM
Dave J's Avatar
Dave J
Both my cars still with points......
Paul L's Avatar
Paul L
I don't understand your message. Seven out of nine what?
Old Oct 8, 2013 | 08:13 PM
Mooser's Avatar
Mooser
Points here too
Was HEI, went to points, to pertronics, back to points.
M
Old Oct 8, 2013 | 08:27 PM
learje's Avatar
learje
points here, thought about changin when i rebuilt my dizzy, but since i spent a couple decades maintaining 1950s airport ground support equipment- figd id stick w what i know
Old Oct 8, 2013 | 08:47 PM
kdf1986's Avatar
kdf1986
In my 72 I have the points and condenser.
In my 73 I changed to a Pertronix setup when I was chasing an engine problem. But it turned out not to be ignition related so I may change back.
In my 75 its a HEI unit.
kdf
Old Oct 8, 2013 | 08:56 PM
Brcmpbl's Avatar
Brcmpbl
Seven out of his nine cars I suspect.
My 70 still has points and condenser, and I will never change it over to HEI. My 76 has factory HEI and it is fine as well.
Old Oct 8, 2013 | 10:18 PM
GRipp 73's Avatar
GRipp 73
Count me in for the points and condenser as well. The current system has been in place since 1991. I think it is time to do some maintenance. It is going to be a fun winter!
To How many running points and condenser
Old Oct 8, 2013 | 10:54 PM
GPGG70's Avatar
GPGG70
My 70 coupe has points/condenser.
My 70 convertible has the Pertronix installed.
Old Oct 8, 2013 | 11:52 PM
PeteZO6's Avatar
PeteZO6
If your heart is set on going to electronic ignition, the Breakerless SE UNIT FROM Lectric Limited is the way to go. It uses one wire, just like the points system. No wiring mods! Completely enclosed within the distributor. Pricier than the Petronix, uses the stock coil, AND the stock resistance wire. No mods. http://www.lectriclimited.com/mainpage.htm
Pete
Old Oct 9, 2013 | 12:11 AM
mrmagrath's Avatar
mrmagrath
Bubba had already equipped my 74 with an HEI, most likely from a 77. Just fitted a tach drive HEI, yes, probably from China! Haven't connected the cable up yet, because Bubba moved the oil pressure sender to behind the inlet manifold, and I'm waiting on the adapter to move it back from Corvette Central. But the distributor goes really well. So far.........
But in a perfect world, I'd rather have the original setup.
