Power Steering Pump
Old Nov 29, 2013 | 11:15 AM
Cavu2u's Avatar
Cavu2u
Default Power Steering Pump
As I said before, I got lots of parts, some brand new, with this car. One part was a new power steering pump.
It doesn't seem to fit.
Does this pump look like any of yours out there? The axle's neck it too long for the way I think it mounts (which I may be doing wrong), as the pulley wouldn't clear the car's frame even if it would be able to mount up.
Any thoughts greatly appreciated.
Steve
Old Nov 29, 2013 | 11:34 AM
mds3013's Avatar
mds3013
For my '77 that pump is not even close. The pulley is more inline with the yellow arrow in your pic.. The pulley could hit the frame if the belt was too long. Trying to find a pic. of mine. mike...
Old Nov 29, 2013 | 11:36 AM
BOSTONCAMARO's Avatar
BOSTONCAMARO
for starters...pulley looks to be on inside out....
Old Nov 29, 2013 | 11:38 AM
mds3013's Avatar
mds3013
From the '77 AIM. Your '73 may well be completely different. mike...
Old Nov 29, 2013 | 11:40 AM
BOSTONCAMARO
here is mine, I believe someone swapped in a pump with double pulley years ago
Old Nov 29, 2013 | 11:50 AM
7T1vette's Avatar
7T1vette
Pulley is installed backwards.
Old Nov 29, 2013 | 03:45 PM
Jim Shea's Avatar
Jim Shea
I hope that someone didn't press directly on the pulley to get it on the pump driveshaft. And yes, the pulley is backwards on the pump shaft.
Now the really bad news:
You must use a special tool to thread into the end of the driveshaft and draw the pulley onto the shaft. Pressing directly on the pulley and reacting against the pump housing will most likely break parts inside the pump.
Jim
Old Nov 29, 2013 | 04:29 PM
Cavu2u's Avatar
Cavu2u
Thanks.
I told you guys I'm an idiot.
Here's proof.
Steve
Old Nov 29, 2013 | 06:37 PM
Cavu2u's Avatar
Cavu2u
Default Fits Fine
Thank you BostonCamero & Jim S.
Steve
To Power Steering Pump
