Dash bracing
Old Mar 11, 2014 | 03:47 PM
Perfmach1's Avatar
Perfmach1
Default Dash bracing
Does anyone have a picture of these two dash braces. The ones connected to the brackets on the windshield frame, #4 and #6 on the drawing. My car is a 69 conv. and doesn't have these tabs welded there. Or is this for the t-top cars? Thanks
[IMG][/IMG]
Old Mar 11, 2014 | 04:26 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The 19467 in the lower left corner of the AIM title block indicates convertibles. Everything shown on that page would have been applicable for convertibles. 19437 would be coupes only. 19000 would be all 69s regardless of body style.
Old Mar 11, 2014 | 04:53 PM
Perfmach1's Avatar
Perfmach1
That's what I thought. But there is no sign of these brackets being in my car.
Old Mar 11, 2014 | 05:08 PM
Alan 71's Avatar
Alan 71
Hi P1,
The info I have indicates the braces were installed on convertibles built in April of 1968 onward.
So???
Regards,
Alan
Hi again,
Because I'm curious I took the time to dig out an article about the braces that appeared in the Spring 1993 edition of the NCRS magazine THE RESTORER. It was written by Jim Wood.
He indicates the drawings are dated late January 1968 with revisions in Feb., Mar., and Apr.. He studied a few cars and it confirms the thought that the braces began to appear on cars in the spring of 1968. He mentions a May built car as an example.
Then it gets interesting for a moment…. he writes that the braces continued through the 69 model year. He speculates that the cowl MAY have been changed to a more rigid structure which allowed the braces to be dropped. But in fact, they're still shown in my 71 AIM. Is there any chance the cowl WAS changed and a period of no braces was tried? I'd think not.
So that really does deepen the mystery of your car with no braces.
Old Mar 11, 2014 | 05:14 PM
Jack605's Avatar
Jack605
I have the same issues in my car (69 Convertible) the only brace that is installed it the passenger side one.
Old Mar 11, 2014 | 06:28 PM
Perfmach1's Avatar
Perfmach1
Thanks Alan, My car was built June 69. All of the other bolt in braces under the dash are there. Just missing those two. Somebody sleeping on the job that day.
Old Mar 11, 2014 | 06:45 PM
7T1vette's Avatar
7T1vette
I thought those braces were for cars with C60 option only (air conditioning). At least, that's what my AIM indicates.
Old Mar 11, 2014 | 06:47 PM
Alan 71's Avatar
Alan 71
Hi pf,
What's interesting to me is while the workmanship on the 68-72 cars was frequently disappointing, I don't read about cars having left St. Louis missing parts.
So still????
Regards,
Alan
Old Mar 11, 2014 | 07:39 PM
Perfmach1's Avatar
Perfmach1
Mine has no a/c.
Jack605 does your car have a/c?
Old Mar 11, 2014 | 08:55 PM
mysixtynine's Avatar
mysixtynine
My 69 convertible only had heat and it had all the braces like it's supposed to.
I had to relocate the lower one when installing my vintage air and do a small mod to the upper brace. You can search for my vintage air install pics about relocating my braces.
Old Mar 11, 2014 | 09:18 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
here is a pic. of the two braces. I was not documenting the braces, so maybe not the detail you are looking for.
My car is a late Oct. 69 build with no AC. My AIM shows the page above as standard for non AC convertibles. The AC convertibles had additional bracing attached to a saddle mounted to the transmission hump.
Old Mar 11, 2014 | 09:29 PM
Jack605's Avatar
Jack605
Originally Posted by Perfmach1
Mine has no a/c.
Mine does not have AC
I do not have the brackets on the drivers side
Old Mar 11, 2014 | 09:47 PM
Perfmach1's Avatar
Perfmach1
Thanks c69vete, that helps. I'll look at mine tomorrow.
Old Mar 11, 2014 | 10:04 PM
c69vete's Avatar
c69vete
St. Jude Donor '07
Old Mar 11, 2014 | 11:34 PM
68/70Vette's Avatar
68/70Vette
FYI. My May 15, 1968 Convertible has all the braces.
Old Mar 12, 2014 | 07:56 AM
70BBvert's Avatar
70BBvert
A couple of pictures of my 70 Convertible, Late build, July 70
Jim
Old Mar 12, 2014 | 08:32 AM
Perfmach1's Avatar
Perfmach1
Thanks 70BBvert, great picture. Those brackets were never in my car.
To Dash bracing
Old Mar 12, 2014 | 08:41 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by 7T1vette
...I thought those braces were for cars with C60 option only (air conditioning). At least, that's what my AIM indicates...
Check your AIM again. In the C60 AC section it shows a different lower brace that only the AC cars got.
Originally Posted by 68/70Vette
...FYI. My May 15, 1968 Convertible has all the braces...
Different model year. The OP has a 69. My 68 also has the braces, same as yours, but the configuration may have been another one-year-only thing for us.
Old Mar 12, 2014 | 11:41 AM
7T1vette's Avatar
7T1vette
Got it! Thanks...
Old Mar 12, 2014 | 12:55 PM
70BBvert's Avatar
70BBvert
No problem, I had to re weld the two side brackets as they came loose during the rebuild, the drivers side was barely held on and fell off.
Maybe the car was originally a coupe???
Jim
