Torque Specs
Old Apr 3, 2014 | 05:44 PM
SB64's Avatar
SB64
Default Torque Specs
I have the AIM which shows some specs but not all parts, at least I could not find everything. Is there a site that would have for example all the torque requirements for the front end work that I have done. Upper lower control arms, etc???
Old Apr 3, 2014 | 06:18 PM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Found this for starters;
http://forums.corvetteforum.com/c3-t...g-on-a-c3.html
Terry
Old Apr 3, 2014 | 06:30 PM
Mooser's Avatar
Mooser
Between the AIM and the service manual the only value I haven't come across yet is the center bolt (thin head one) that hold the top of the spindle to the caliper bracket.
Which ones are you missing?
M
Old Apr 3, 2014 | 07:55 PM
SB64's Avatar
SB64
Default torque
M
I forgot to check the service manual thanks for your help M
R
Old Apr 3, 2014 | 07:58 PM
SB64's Avatar
SB64
Default specs
Originally Posted by HOOAH
Perfect Will print out for now. Just what I was looking for. I wonder what book those pages are from. Thanks H
Old Apr 3, 2014 | 11:12 PM
7T1vette's Avatar
7T1vette
The AIM only shows detail for the work done AT THE VEHICLE ASSEMBLY FACTORY. Any sub-assemblies that were produced elsewhere and sent to the final assembly building will not have any detail info in the AIM.
Old Apr 4, 2014 | 08:17 AM
SB64's Avatar
SB64
Found my old Chiltons, and that has allot of the specs I need , except you have to read each section to find the info. May print out that list posted, it will make things easier.
Old Apr 11, 2014 | 08:44 PM
SB64's Avatar
SB64
to the top
Old Apr 11, 2014 | 10:08 PM
Mooser's Avatar
Mooser
Still not sure which ones your after
Here's a screen cap is my working file, updated one is in the garage
M
File Type: pdf
Old Apr 12, 2014 | 03:00 AM
SB64's Avatar
SB64
That will do it Mooser, I like it and I will use it, thank you for your help.
To Torque Specs
