Zinc Plating
Any recommendations of services that you have used to yellow zinc plate items at a reasonable price?
Also, if it is yellow cad you're talking about, my very limited experience is that you just can't go to a cad plater and ask for a piece to be cad plated. My experience is that they will only do mass plating...you got to show up with say 100 pounds of parts for them to plate. It's the EPA problems..cad is a very toxic metal...and platers are harrassed by the EPA. I think there are some plater shops serving the repro community that will accept parts for cad plating. They take a lot of customers parts, store them, and when they get a large amount, they take them to the cad platers....I've never had parts cad plated because of all these problems.
If you're not worried about appearance, no one will see you're inner door parts, and you really want them plated, just take them to a chrome shop and have them nickel plated. Regular paint is an option. Eastwood make cadmium lookalike paints. You spray on the basic yellow, and then two other cans will give some green and reddish highlights.
I've installed a lot of "new" parts on my 68. Including many cad plated resto parts. They are prone to corrosion just like the original parts. Cad plated parts are not very durable. My opinion is that if you don't have a climate controlled garage,you can spend a lot on money on recreating cad plated parts only to have
Not an endorsement, I've never used these products. I'm a big fan of powder coating too..
I also use powder coating as much as I can but some parts just cant be coated as the paint is fairly thick and if its threaded, forget it.
I live in the peoples republic of CA and its fairly easy to find platers still.
If it's the same cost, either way, get the gold wash also. There is some additional benefit for the time it remains on the surface.
This is an example of the old plating system you describe… zinc plating and then a dichromate wash.
The size of the piece being plated is limited only by the size of the tank being used and the amperage limit of the power supply.
Regards,
Alan
This is a small system from Casswell.
This is zinc plating, zinc with dichromate wash, black oxide plating, and manganese phosphate plating on original fasteners and parts.
This is zinc plating (which is normally dull) with 'brightener' in the plating solution.
This is a front caliper bracket that was zinc plated and the dipped in the dichromate wash.
This is an original gas cap that has been zinc plated in a solution with 'brightener'.
Is that your setup, Alan? How difficult is it to learn how to do it properly?
Yes, that my current set up.
It's the Zinc/ Copy Cad System from Casswell, it's not cheap because you need a power supply too.
The system itself is really quite easy to learn to use, and then continue to use.
I also have the Black Oxide System from Casswell which is VERY easy to use and get good results from.
For zinc phosphate (light gray) and manganese phosphate (dark gray) I use materials from Palmetto Enterprises.
For all the types of plating preparation is extremely important. All rust must be completely removed and the part must be scrupulously clean.
My method is slow but I seem to be getting good results. I only have a little experience doing the chromate wash so will hopefully learn how to control the amount of color and the various hues the dichromate should exhibit.
Thanks for the interest. This is one of those things that interests me but doesn't amount to anything in the grand scheme.
Regards,
Alan
This is the set up for doing phosphate.
A stainless or glass container, the solution heated to 200 degrees, the parts suspended in the solution.
My wife just loves me to use the kitchen for my car activities. She has a lot of direct comments when I use the dishwasher to clean parts. The oven to bake parts..not powder paint..just heat to evaporate stuff.
Yes, I'm really cautious around the dichromate solution.
After the zinc plating is compete I rinse the part throughly, then dip it in a muriatic acid solution for a few seconds, dry it, and then into the dichromate bath.
The length of time it's in the solution determines how much color you get.
Regards,
Alan
