Headlight open/close speed?
Old Apr 30, 2014 | 11:31 AM
ChrisMiami's Avatar
ChrisMiami
Default Headlight open/close speed?
Assuming no mechanical issues like sticking hinges, what components determine the speed that the headlights open?
I'm thinking the vacuum pressure is probably the main thing, but even if it's boosted, would the actuators need to be adjusted somehow (and if so, how)?
I am thinking I'd like mine to snap! open/closed rather than slo-o-o-o-lllly eas. ing u-u-u-P-P-P.
Old Apr 30, 2014 | 01:46 PM
GreenDream's Avatar
GreenDream
The speed is certainly reliant on vacuum. Mine do snap open and closed. No drag, but I just recently rebuilt the canisters and installed new relays.
Old Apr 30, 2014 | 01:54 PM
Alan 71's Avatar
Alan 71
Hi CM,
Assuming there is sufficient vacuum in the system, including the vacuum tank, once the actuators receive the open or close vacuum supply from the relays, it can only be the quality of the seal of the red and green hoses on the relay nipples and the actuator pipes, and the quality of the seals in the actuators, that determines how the doors react.
They can and should snap open and closed in unison.
Regards,
Alan
Old Apr 30, 2014 | 02:51 PM
jdbuddy's Avatar
jdbuddy
Originally Posted by Alan 71
Hi CM,
Assuming there is sufficient vacuum in the system, including the vacuum tank, once the actuators receive the control signals from the relays, it can only be the quality of the seal of the red and green hoses on the actuator pipes, and the quality of the seals in the actuators that determine how the doors react.
Regards,
Alan
Mine has a lazy left eye....but things could be worse.
Old Apr 30, 2014 | 03:07 PM
FireballXL5's Avatar
FireballXL5
Mine has a lazy right eye... Takes a few secs to pop up... There's lots of vacuum lines funning to and from those systems... And potentially, could be collapsing hoses...?
When I bought my vette the PO said he paid a bunch of money to have them fixed, but then a month later they just started staying up... He wasn't a mechanic himself and never looked into them... Every time I turned the lights off if hear a constant hissing under the dash, figured a hose had unplugged or failed... First time crawling under the drivers side I saw this little pull down plunger with vacuum lines running to it... Pushed in in/out a few times and wondered what it was for... Thought to myself , could it be THAT simple?
Fired up the vette, pushed in the plunger, and low and behold... The lights went down perfectly! And have ever since! Lol. It's been crazy how many 'issues' on my vette have been fixed by something soooo simple... Guess my PO had more dollars than sense ...
But anyways... If they're really sluggish, I might look into tracing all the vacuum hoses and putting fresh on to make SURE they aren't collapsing from age... Might be the cheapest/easiest thing to look at before checking diaphragms and mechanisms...
Old Apr 30, 2014 | 03:10 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ChrisMiami
...I am thinking I'd like mine to snap!...
I'm thinking you'll settle for having the pair open and close together in a reasonable time. The pair on my 80 open and close together in about five seconds or so; never timed it. The pair on my 68 start to open together, but the right slows down a bit. They close together.
I can live with it.
Old Apr 30, 2014 | 03:35 PM
Dave J's Avatar
Dave J
Most believe the actuator seals are the primary focus to snap headlights up and down. I also have found that the relays are an equal opportunity culprit. The main issue with relays that are older originals, or of questionable origin (imports) is the internal piston. The piston directs the actuating vacuum to and from the two ports. When the rubber piston becomes brittle or is malformed, it no longer seals against the piston walls. This will not allow a fast transfer of actuating vacuum to the opposite vacuum port. Thus, you have prolonged headlight opening times.
Some believe that the vacuum system requires a lot more vacuum pressure to operate the system than what is actually required. I've blueprinted the systems in my 2 cars, and have no leaks. I can cycle the headlights with 8 lbs of vacuum pressure. If you have leaks, you probably are already dealing with reduced vacuum pressure anyway.
Let me know if you want to fix yours......
Old Apr 30, 2014 | 03:44 PM
dochorsepower's Avatar
dochorsepower
"Assuming no mechanical issues like sticking hinges, what components determine the speed that the headlights open?"
The rotation of the earth, tidal conditions, the stock market and what you had to drink last night.
Old Apr 30, 2014 | 03:47 PM
FireballXL5
Or you could change your focus to the 'speed of dark' instead of the 'speed of light'... Might have more luck there... Lol
Old Apr 30, 2014 | 04:45 PM
oldgto's Avatar
oldgto
[comedian Steven Wright]"If you were in your vehicle, traveling at the speed of light.... when you turn on your headlights.... would they do anything?"[/comedian Steven Wright]
Old Apr 30, 2014 | 05:14 PM
7T1vette's Avatar
7T1vette
Slow headlights are usually due to bad seals in the vacuum relay(s) for the light buckets. You can check this out by simply bypassing the relay for each light.
Remove the main vacuum supply hose from the relay (center hose) AND remove both of the hoses on one of the headlight actuator cans. Hook the supply hose to one of the actuator can fittings (engine running, of course). The door will either OPEN or CLOSE; and, if you have a decent vacuum supply without much leakage, it should be pretty quick. Then, remove that hose and connect it to the other fitting. The headlight door should reverse direction...again, rather quickly.
If that all works as expected, you need to replace the vacuum relay unit for that light.
Old Apr 30, 2014 | 05:15 PM
Snoopysvet's Avatar
Snoopysvet
I have to get out of the car and give them a gentle nudge to go up or down, I think I just might spray some lube at the hinges first?
Old Apr 30, 2014 | 05:26 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
orginal setup uses 1 pilot actuator for "each" headlight, which makes it very common for the lazy eye effect.
when I built mine I elected to use only 1 pilot actuator to open, both headlights at the same time.
I believe in later years GM moved to 1 pilot actuator, for both buckets also.
slow opening for both ? you most likely have other leaks to find.
best way to tackle vacuum problems, remove and plug the ports on engine side,
for ALL vacuum lines leaving the engine,
establish your best vacuum with a gauge, start adding back the vacuum acc.
if your base vacuum and fully connected vacuum are the same. you have no leaks.
Old Apr 30, 2014 | 05:52 PM
Mike Ward's Avatar
Mike Ward
Originally Posted by 69Vett
orginal setup uses 1 piolot actuator for "each" headlight, which makes it very common for the lazy eye effect.
You mean 'relay'. Many years used two relays. In a properly operating system both lights snap open or closed almost instantly, at the same time.
Try installing a vacuum gauge near one of the actuators. If the reading is not stable and very close to intake manifold vacuum levels, there's at least one leak.
Most people do nothing till the system stops working entirely and then only enough troubleshooting to get it somewhat functional.
I've seen very few cars that are 100% like new.
Old Apr 30, 2014 | 11:51 PM
ChrisMiami's Avatar
ChrisMiami
@DaveJ - darn right I wanna fix 'em! How do I ensure the new relays are quality parts?
Anyone know of a reference video that shows what "like new" acts like? I've seen plenty of anemic and lazy-eye examples, but nothing to make me say "now that's what it oughtta be"!
I've got a coil of silicone vacuum hose but I think the I.D. is too small, will get the right size when I can.
@7T1vette, @69Vett, @Mike Ward - thanks for the procedures, always welcome as I learn my way around.
Chris
Old May 1, 2014 | 12:20 AM
Ironcross's Avatar
Ironcross
Default Wild camshafts
High performance camshafts with low vacuum is also a culprit {ie L-88 or better} will also make them slow to react, especially too close.....
Old May 1, 2014 | 12:31 AM
FireballXL5
If mine go up and down... I don't really care about how 'fast' they are ... Now... Is it just me... Or does everyone else's headlights wiggle as you drive down the road and hit bumps ? Didn't know if THAT was inherent to the C3... Or something I should look into... Just has a slight vertical wiggle over bumps on the freeway...
To Headlight open/close speed?
Old May 1, 2014 | 07:46 AM
tak82's Avatar
tak82
FireballXL5 there shouldn't be a wiggle, you may want to look for a loose bolt or shaft wear. And tell me if I'm wrong, what gives the headlights the "snap" is the springs. The actuators only push them up or down but the actually should move at a constant rate through the length of the piston, the spring are giving it the quick snap. Grab the mechanism and move it manual, they will slam up and down. ChrisMiami your slow movement is another story, sounds like you needs to do a system tune up..
Old May 1, 2014 | 10:51 AM
69Vett's Avatar
69Vett
when the corvette headlights open to full extension, they pass over a cammed fulcrum point, backed up by a stiff spring, this setup,
and adjustment control the snap or Not, which is actually locking them into the open position,
if your headlight assy. wiggles you may other issues.
Old May 1, 2014 | 11:41 AM
FireballXL5
Good to know... I'll investigate ;-)
