View Poll Results: Which do you prefer
Drop Spindles that use an OE hub
40
66.67%
Drop Spindles that use a C5/6 bolt on hub
8
13.33%
Not Interested
12
20.00%
Voters: 60. You may not vote on this poll
Drop Spindle Poll
Old Feb 24, 2015 | 03:20 PM
  #61
13611's Avatar
13611
Bad Bird, yes... that's their goal. Ref post 44 and 53.
Old Feb 24, 2015 | 03:31 PM
  #62
Bad Bird's Avatar
Bad Bird
Sure, that was their stated goal. However they have now decided to use the C6 bearing back on their new spindles, so I wonder how they intend to incorporate factory brakes.
Old Feb 24, 2015 | 10:19 PM
  #63
509 rat's Avatar
509 rat
I hear that raising the diff in the c3 vettes make a improvment, but guys like me that installed a t56 trans would make the angle more drastic, I would have to angle the diff up about 2 degrees , being that my tranny is about 2 degres pointing thew other direction, oposite but same angle means no vibration.
Old Feb 24, 2015 | 10:50 PM
  #64
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
The improvement had by raising the diff in a lowered chassis is to compensate against the rear suspension otherwise ending up working from an adverse point on the tow-steer curve. Bearing in mind that from the point at which the half-shafts become level rear toe travels progressively towards toe-out, the rule of thumb is to have the inner u-joints ~1/2" higher than the outers at static ride height when all is done. This isn't something I'd skip doing over having to re-set the pinion angle. My $.02
Old Feb 25, 2015 | 10:17 PM
  #65
509 rat's Avatar
509 rat
Default thanks
very enteresting.
Old Oct 28, 2015 | 06:05 PM
  #66
professor_speed's Avatar
professor_speed
Any updates on the drop spindles?
Old Oct 28, 2015 | 06:17 PM
  #67
The13Bats's Avatar
The13Bats
I would have voted stock brakes but what would the entry price be, coil overs or vbp transverse front spring have adjustment drop spindles do not so they would need a better price for us budget ( cheap ) builders...
Old Oct 28, 2015 | 08:43 PM
  #68
The Phantom's Avatar
The Phantom
Drop spindle ... yes I'm in, as long as I can use my Steeroids Rack without issue.
Dave
Old Mar 19, 2016 | 06:54 PM
  #69
Cowansauto's Avatar
Cowansauto
any updates on the drop spindle?
Old Mar 19, 2016 | 08:06 PM
  #70
SB64's Avatar
SB64
Default survey
Yes to the OE dropped spindle.
Old Feb 18, 2017 | 08:33 AM
  #71
Supercobra's Avatar
Supercobra
Any updates on the spindle or did this project die?
