drawing
Old Oct 2, 2014 | 03:16 PM
hardlanding's Avatar
hardlanding
Default drawing
anyone by chances have a detail drawing of the rear hubs, I am gonna make the tool to check the tolerance. I think
Old Oct 2, 2014 | 04:36 PM
blueray72's Avatar
blueray72
Are you talking about rotor run out?
Old Oct 2, 2014 | 05:16 PM
hardlanding
No the spindle it self...
Old Oct 2, 2014 | 08:54 PM
Alan 71's Avatar
Alan 71
Hi hl,
Since the part is readily available to use to build your tool why would you go back to a drawing?
That seems like a step in the wrong direction.
If you need the spindle drawing to generate a tool drawing can't you do the spindle drawing yourself based on the actual part?
Regards,
Alan
Old Oct 3, 2014 | 08:18 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What is "tol"? Toe, maybe?
Old Oct 3, 2014 | 09:33 AM
hardlanding
Originally Posted by Alan 71
Hi hl,
Regards,
Alan
I wanna have my shop turn one for me before I tear it apart, and use that instead of paying for the tool.
tolerance*
Old Oct 3, 2014 | 11:03 AM
Mike Ward's Avatar
Mike Ward
tolerance*
Which 'tol' are you checking?
Did you mean clearance?
Old Oct 3, 2014 | 04:38 PM
hardlanding
checking the bearing play at assembly
Old Oct 3, 2014 | 05:43 PM
Mike Ward's Avatar
Mike Ward
You'll pay more to have the spindle tool made from scratch than it costs to buy one.
Find an old spindle and have the bearing surfaces turned down a few thou till the inner races are a slip fit.
To drawing
