setting the timing?
Old Nov 23, 2014 | 11:09 AM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
Default setting the timing?
I know the timing is supposed to be 4 degrees BTDC for a 79 L-48. since my motor was rebuilt before I purchased it and was built to 225hp it has a larger cam in it. I DO NOT HAVE ANY SPECS ON THE CAM THAT WAS INSTALLED.My question is where would you set the timing?? and at what rpm???
Old Nov 23, 2014 | 11:48 AM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Back in the 60s, when we could not afford a timing light, we used to keep the distributor bolt finger tight, then keep advancing it until the engine rattled under load at low rpm...then we backed it off a notch and tightened the bolt. Your engine will know what the timing should be...given the gas in the tank and the atmospheric conditions.
Old Nov 23, 2014 | 12:04 PM
REELAV8R's Avatar
REELAV8R
Between 10* and 16* BTDC. All in of 36* by 2800 RPM. So you could end up at 16* on the initial if you have 20* total mechanical advance to achieve 36* total. If it's too much and you encounter pinging at WOT reduce 2* at a time until it goes away.
To get the real skinny on timing email lars for his latest papers.
Old Nov 23, 2014 | 01:10 PM
bj1k's Avatar
bj1k
That's funny that you mentioned that. Back in the 60's my uncle used to race stock cars and didn't believe in timing lights. " He said it's all in the ear son. " He could really make a car hum .
Old Nov 23, 2014 | 02:34 PM
lars's Avatar
lars
Unless you're trying to pass an emissions test, the last thing you want to do is set the timing at 4 initial.
My current timing paper has the complete setup procedure along with recommended specs for different applications. Just e-mail me for a copy.
Lars
V8FastCars@msn.com
To setting the timing?
