Engine serial #'s
Old Nov 24, 2014 | 09:25 PM
Red Hot 71's Avatar
Red Hot 71
Default Engine serial #'s
Trying to find out more about my Vette. Found this stamped on the block. 1st line: VO320ZBC / 2nd line: 1AS434432. It is titled a 1971 coupe. Please help me figure out what this all means.
Old Nov 24, 2014 | 09:41 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Looks like your red hot 71 is powered by a 1980 Corvette motor
ZBC 1980 350 a/t, L82 6 230 4 Vette
Old Nov 24, 2014 | 10:08 PM
MakoJoe's Avatar
MakoJoe
here is 2 links to websites that shows Fred's findings
http://www.corvettecenterusa.com/Cor...ne%20Codes.pdf
http://www.nastyz28.com/gm-chevy-cod...-suffix-10.php
Old Nov 25, 2014 | 08:12 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...VO320ZBC...1AS434432...
1980 L-82 out of #34432.
Old Nov 25, 2014 | 08:25 AM
joewill's Avatar
joewill
engine was assembled march 20, 1980
Old Nov 25, 2014 | 04:44 PM
Alan 71's Avatar
Alan 71
Hi RH71,
The first group of digits and letters is known as the assembly information.
It describes which plant the engine was assembled in, the date it was assembled, and the configuration (for what application) it was built in.
The second group of digits and letter is know as the VIN derivative.
This stamp is a record of the serial number of the car the engine was installed in at St.Louis.
Hope this helps you understand what you're seeing on your engine's pad, and also the answers above.
Regards,
Alan
To Engine serial #'s
