toggle switch
Old Mar 13, 2015 | 03:10 PM
blue by you's Avatar
blue by you
Default toggle switch
hey Guys and Gals, The other night I was removing my radio from my 71 coupe and when I was removing the convertor from the firewall on the passenger side I noticed a toggle switch mounted to the firewall, but it didn't look like it came from the factory. Any thoughts and no I did not take any pictures of it.
Old Mar 13, 2015 | 03:25 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
There are no factory toggle switches behind the dash.
Old Mar 13, 2015 | 03:42 PM
Paul L's Avatar
Paul L
GM did not use toggle switches. Is the switch wired to something? Your description is pretty vague.
Old Mar 13, 2015 | 04:16 PM
7T1vette's Avatar
7T1vette
Trace the wires from that switch. If it goes to the ignition coil or distributor, it is likely a (owner installed) theft-prevention device that is used to 'break' 12 vdc from getting to the coil. Flip it, and the car won't start. Flip it the other way and you're good to go.
Inexpensive and it works great....as long as the thief can't find the switch!
Old Mar 13, 2015 | 04:35 PM
blue by you
yes it is wired to something, I will take a picture and trace the wires
and let you know what I find. I didn't think it was factory.
Old Mar 15, 2015 | 02:50 PM
blue by you
Well, I did trace the wires and it was a kill switch. I rip it out and wired it correctly, didn't want to get stuck with a 30 year old switch failing.
Thanks for all of the help, Once again
Old Mar 15, 2015 | 03:38 PM
Paul L's Avatar
Paul L
Actually they do work well. I had a kill toggle switch on my 1979 many moons ago. This pic from about the year 2000. See red wires, top left.
To toggle switch
