I am not having any luck securing the battery in the battery compartment. What is the trick to tightening the clamp against the battery?
I have a NAPA battery 7875 with the side posts facing the rear. Every time I position the battery and tighten the bolt on the clamp the battery is still able to move. There is a small lip near the bottom of the battery that is on the clamp side of the compartment. I assume this is used for clamping the battery down. The lip is very small and almost unnoticeable.
I have attached a pdf of the battery compartment from the 74 AIM.
The battery needs to be the correct width, in order for the #6 clamp to "hook" the lip at the bottom of the battery case, and then the bolt holds the #3 clamp in place, after it has "hooked" the lip on the other side of the battery.
My #4 and 5 were long gone, vaporized from road salt I assume, when I got my car. I found #6 under the battery! You have to love living in the salt belt. Mike
Hi Dave,
If the battery has a groove in it's case to receive the lip on item #1 you may need to flatten #1 a little so it extends further and is able to grab the battery case.
I had to do that.
Regards,
Alan
I'm having the same problem as Mr74 with my 1978. I suspect that the dimension of the battery is the problem. As I am ready for a new battery does anyone know what the original battery dimensions is/are so that the base lips of the battery are compatible with the holddowns (#6 and #1)? I simply cannot make it work with the battery I have. Thanks in advance.
