1981 fuse box issue
Old Jun 5, 2015 | 09:09 PM
K9BLADE's Avatar
K9BLADE
Default 1981 fuse box issue
I used one of the "always hot" accessory plugs marked "bat" on the fuse box to run a new horn. It was working fine but now the plug has no power. Is that bat plug controlled by a fuse?
Old Jun 15, 2015 | 10:03 AM
K9BLADE's Avatar
K9BLADE
Default Second request - Anybody have an answer?
Can anyone help with this issue?
Old Jun 15, 2015 | 06:55 PM
bj1k's Avatar
bj1k
Are you getting a good ground when you use your test equipment. If it had power it should still have power. There is no fuse for those terminals . They are always hot. I suspect that you just need a good ground on your tester which is hard to find on these cars sometimes. Run a ground straight to your battery - terminal.
Old Jun 15, 2015 | 09:32 PM
The13Bats's Avatar
The13Bats
A horn is a high demand it should always be wired with a relay,
I had 2 81's you would think I would remember the Bat term but I do not...you "could" have fried a wire if you had a high draw horn on it and the wire had no fuse to blow first.
Old Jun 25, 2015 | 03:27 PM
K9BLADE's Avatar
K9BLADE
Thanks. I hooked up a one horn kit which didn't require a fuse. The "bat" plug had power but now doesn't. The fuse right above it (20amp) has blown and blows instantly if I put a new one in. Name:  1981 fuse box.jpg
Old Jun 25, 2015 | 03:29 PM
K9BLADE's Avatar
K9BLADE
Did that.....still no power. 20 amp fuse above "bat" now blown and new fuse blows right away.
Old Jun 25, 2015 | 04:54 PM
rastafford3164's Avatar
rastafford3164
It appears you have the fuse box removed. Can you see where the wires for the Bat and the 20 amp circuit connect to it? Was wondering if the Bat terminal or wiring got too hot and melted over onto the 20 amp connection. What else isn't working? Don't have a pdf of my owners manual on my work computer and don't remember what is on that 20 amp circuit
Old Jun 25, 2015 | 04:59 PM
K9BLADE's Avatar
K9BLADE
It's not my actual fuse box just a pic for reference. I do like your theory though. Thanks.
Old Jun 26, 2015 | 06:46 PM
DUB's Avatar
DUB
OK....the 20 AMP AMBER FUSE.....that is..from the bottom....the second row UP and the second fuse ON THAT ROW.....CORRECT?
IF it is.....this fuse it your courtesy fuse.....so interior compartment lights...cigarette lighter, power door lock possibly, rear spare tire carrier light, visor light interior timer controller, radio and I believe antenna relay are powered BY THIS FUSE.
NOW....because I am not at work right now and do not have my book with me....but if I follow GM's previous design ideas. IF you remove THIS 20 AMP fuse....Go in with a volt meter and check to see which fuse terminal has 12 volts to it with the FUSE OUT. MY bet ...the LEFT terminal will be 12 volts. AND the TWO 'BAT' terminals should have NO power to them. CHECK THIS AND CONFIRM!!! SO...when you get this 20 AMP fuse to not pop.....the fuse protects the TWO 'BAT' terminals if you hook something up to them.
NOW...GM could have switched it.....and made it so the RIGHT TERMINAL on the 20 AMP fuse is 12 volts.....THUS....the two 'BAT" terminals are also battery power at all times.
BUT REGARDLESS....Back to the 20 amp fuse that is popping. The terminal that you find is battery pwoer....the other one will show to be GROUNDED.....and that is what is causing you fuse to pop. SO...You have to go to each item that this fuse is supplying power to and disconnect it and see when the terminal finally is no longer grounded. IF you have all components disconnected....and the terminal is still GROUNDED....you have this wire touching something steel in the car.
DUB
Old Jun 27, 2015 | 09:37 AM
Street Rat's Avatar
Street Rat
I wish that darn fuse box was this easy to access.
I hate anything to do with it.
Old Jun 27, 2015 | 05:46 PM
DUB's Avatar
DUB
You do not have to remove the fuse box to do what I wrote.
DUB
Old Jun 29, 2015 | 01:08 PM
K9BLADE's Avatar
K9BLADE
Default 1981 Fuse box issue
Thanks for the info DUB. If you do get a chance to look at your book could you please post the list of what is actually controlled by that fuse? I'm starting with the cig lighter and interior lights which I know are controlled. Thanks again.
DUB
To 1981 fuse box issue
