headlamp actuator
Old Jul 15, 2015 | 03:49 PM
ballen06's Avatar
ballen06
Default headlamp actuator
I just bought a pair of headlamp actuators and they look great. The problem is they don't have enough stroke to do their job.
They have around 1.75 in stroke... I would like around 2.5 in.
Is there anyway to increase the stroke on these actuators? Screw/unscrew the push pull rod?? Does anyone have experience with this?
Old Jul 15, 2015 | 05:26 PM
Richard454's Avatar
Richard454
There is no internal adjustment-
https://www.corvetteforum.com/forums...-actuator.html
Old Jul 15, 2015 | 07:49 PM
DUB's Avatar
DUB
I have run into the length of the threaded shaft coming out of the actuator that you spin the eyelet onto being different lengths. I CLEARLY remember that in the past.
I believe I still have the actuators on the shelf showing the different lengths in the threaded shafts....if I find them...I will measure them and get back to you and or post a photo.
PLEASE give you year model when you post. It always helps.
DUB
Old Jul 16, 2015 | 09:29 AM
Richard454's Avatar
Richard454
Hey Dub-
I have cut them apart-there is nothing internal to adjust on the OEM ones. OEM Rod is on the left- next to the 5/16 threaded rod I used to set up my electric headlight motors
Now the aftermarket ones?
DSCN4758 by Richard Hayes, on Flickr
DSCN4753 by Richard Hayes, on Flickr
Old Jul 16, 2015 | 06:23 PM
DUB's Avatar
DUB
Richard....I agree....there is nothing inside the actuator that allows for an adjustment. But I had a 'brain fart' and forget to look for the pods I have that actually have different length rods coming out of them.
I am sure your electric motor conversion is spot on!
DUB
To headlamp actuator
