Correct Tire Pressure...
Old Aug 4, 2015 | 05:41 PM
Richard Cooper's Avatar
Richard Cooper
Default Correct Tire Pressure...
can someone tell what the correct tire pressure is on my 81? I know there is a sticker on the drivers side door, but its so faded I cannot read the numbers. I just had new tires put on and want to make sure the pressure is right. Thanks.
Old Aug 4, 2015 | 05:53 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
do you have a owners manual? but generally a good PSI for radial tires is 32
Old Aug 4, 2015 | 06:14 PM
gbvette62's Avatar
gbvette62
The 81 owners manual, does not give recommended tire pressures, but instead refers the owner to the tire label on the door.
There wasn't a standard tire pressure for 81 Corvettes. The recommended pressure varied by car, based on tire size (225/70 or 255/60), and optional equipment.
I do agree that 32 lb cold, is probably a good balance between ride and handling. I normally run 35 pounds in all of my cars, but I prefer a tire that has a quick response vs a softer ride.
Old Aug 4, 2015 | 06:42 PM
Moose 02 FB's Avatar
Moose 02 FB
the sticker on my 76 says 26 rear and 20 front
Old Aug 4, 2015 | 06:53 PM
AdamMeh's Avatar
AdamMeh
Check the info on your new tires.
Old Aug 4, 2015 | 07:11 PM
gbvette62's Avatar
gbvette62
I would never run pressures that low.
GM first started using radials in 73, and they were still trying to come to terms with them in the mid 70's. Corvettes were also transitioning from a performance car, to more of a touring/luxury car. They were recommending low pressures at the time, to improve the harsh ride normally associated with both Corvettes and radials.
Old Aug 4, 2015 | 08:16 PM
toobroketoretire's Avatar
toobroketoretire
I have always run 24 psi in the front and 20 psi in the rear of my big block '71 and the tread wear is perfectly even. Pressures near 30 psi will quickly destroy the tires because the centers will wear out 3 times faster.
Old Aug 4, 2015 | 08:40 PM
doning's Avatar
doning
35 PSI all around.
Old Aug 4, 2015 | 11:02 PM
7T1vette's Avatar
7T1vette
American car makers posted air pressures that were too low, when radial tires first came out in the US. For most standard width radial tires, 30 psi works well for C3's.
Old Aug 4, 2015 | 11:43 PM
Strokemyaxe's Avatar
Strokemyaxe
Yep. 20/26 is factory smooth ride
Old Aug 5, 2015 | 12:36 AM
Iceaxe's Avatar
Iceaxe
32 PSI all around. 1970, stock rally rims, 245/60-15 BFG's.
Old Aug 5, 2015 | 07:37 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
"Correct" tire pressure is the one you like. I like 32; you may like 30. 28 might float the boat of other folks. It's your choice.
Old Aug 5, 2015 | 08:35 AM
gungatim's Avatar
gungatim
what do the tires say? that is what I generally go by, not outdated specs for tires that are no longer produced.
I used to go by the standard 34 psi all around until the last 10 yrs. or so. I've noted a lot of new tires, especially lower profile, need 50...even modern replacements with newer compounds need more pressure than the old ones in the same size.
Old Aug 5, 2015 | 08:52 AM
4SPDL81's Avatar
4SPDL81
St. Jude Donor '16
My 81' tire door sticker states 35PSI (front and rear) for 225 size, spare also at 35PSI...the fine print also states that these are "recommended pressures"...Good Luck
Old Aug 5, 2015 | 08:59 AM
Richard Cooper
Thank you all very much. The tire installer had all 4 tires set at 30 PSI, guess I'll just leave it at that. Thanks again.
Old Aug 5, 2015 | 09:03 AM
stoutstuff's Avatar
stoutstuff
If you value the fillings in your teeth (and your cars suspension) - never set by what's on the tire. What's on the tire is a maximum that the particular size will hold maximum weight. I'm in the tire industry going on more than 45 years - currently with Cooper Tire Co. Tire manufacturers will always say what is established by the automobile manufacturer. When I was with Pirelli we said + or - 10%. My 255/60R15 Cobras are running +10% @ 22F & 28R. That tire at 20psi has a load index of 1,453 each so just the fronts together would support 2,900 lbs. . Those recommended pressures have as much to do with oversteer and understeer along with handling the weight and forces of driving.
Old Aug 5, 2015 | 09:07 AM
stoutstuff's Avatar
stoutstuff
Richard, I hope your running Cooper's!!!
To Correct Tire Pressure...
Old Aug 5, 2015 | 11:09 AM
gbvette62's Avatar
gbvette62
Mine too. I just had a chance to go pull the cover off of my 81, and it also states 35 psi, front and rear.
My car is fairly loaded. Besides the standard AC, power steering, brakes and windows, it also came with cruise, am/fm cassette, glass tops, power seat, p/mirrors, p/locks, aluminum wheels and the optional P255/60R15's.
Old Aug 5, 2015 | 12:48 PM
Richard Cooper
stoutstuff,
Thanks, that is some cool information. Yes, I have 4 new Cooper Corbra 255/60R 15 on the vette. I am not going out and setting my tires @ 22F & 28R. Thank you very much.
Old Aug 5, 2015 | 01:57 PM
stoutstuff's Avatar
stoutstuff
Richard, My car is a 78 so the recommended pressure is different than your 81. Here's what I found on yours:
1981 Tire and Wheels
Standard Tire size--P225/70R15
Type--Steel Belted Radial"
Inflation Pressure (cold) front--35 PSI rear---35 PSI
Revolutions per mile--(45 MPH)--760
Standard Wheel--Short spoke spider, steel rim--15x8
Wheel Offset= -0.50"
Optional Tire--Good Year Eagle GT"
Size--P255/60R15
Type-- Steel Belted Radial
Optional Wheel--Cast Aluminum
Rim Size--15x8
I don't know if GM made any significant changes to the suspension in those 3 years or if it was mostly fuel ratings being improved by increasing the pressure. If I was you, I would go + or - 10%. Reduce for a smoother ride cruising or increase for stiffer ride if your a hard driver or on the track. As some stated earlier, you can experiment some too within reason. Ultimately you can judge by the tire wear with even being optimal. Too low and you'll wear the shoulders, too high and you'll wear the centers.
Hope I haven't confused you... Jay
