Correct Tire Pressure...
1981 Tire and Wheels
Standard Tire size--P225/70R15
Type--Steel Belted Radial"
Inflation Pressure (cold) front--35 PSI rear---35 PSI
Revolutions per mile--(45 MPH)--760
Standard Wheel--Short spoke spider, steel rim--15x8
Wheel Offset= -0.50"
Optional Tire--Good Year Eagle GT"
Size--P255/60R15
Type-- Steel Belted Radial
Optional Wheel--Cast Aluminum
Rim Size--15x8
I don't know if GM made any significant changes to the suspension in those 3 years or if it was mostly fuel ratings being improved by increasing the pressure. If I was you, I would go + or - 10%. Reduce for a smoother ride cruising or increase for stiffer ride if your a hard driver or on the track. As some stated earlier, you can experiment some too within reason. Ultimately you can judge by the tire wear with even being optimal. Too low and you'll wear the shoulders, too high and you'll wear the centers.
Hope I haven't confused you... Jay
One more time, thank you. Like I said earlier, the tire installer had the pressure set at 35PSI. To me it seemed a little stiffer that it has been, which is why I posted here. Anyway I am going to set all pressures at 32 and see how it feels. I do not drive the car that much so I am not worried about any kind of wear. Thanks again, have a great day.
