Bob's 1969 Resto-Mod Build Thread
Old Mar 6, 2018 | 08:07 AM
  #441
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
Originally Posted by doorgunner
Mention it to him/Put it on a "punch list" rather than having to bring the subject(s) up over and over. He could remove/repair the area with air bubbles in 30 minutes.....I had the same problem with a similar repair.
Yeah, good Idea DG. Maybe post it like a question... Is that white spot an air bubble? I cant tell from the picture.
Old Mar 6, 2018 | 08:08 AM
  #442
NAVY08's Avatar
NAVY08
Anyone know the thickness of the metal that is used for the front frame extensions that runs out to the chrome front bumper? I have heard them called frame horns.
Front Outer Bumper Bracket
This part
Old Mar 6, 2018 | 04:56 PM
  #443
bazza77's Avatar
bazza77
mine are 3.4mm with a coat of primer
in inches that converts to 0.133858267717
Old Mar 6, 2018 | 06:04 PM
  #444
SB64's Avatar
SB64
Default bracket
They are also a PITA to install and get right. The C bracket that attaches to the end of the horn bracket has to sit flush against the fiberglass hole that aligns with the front bumper. Worked all day today and still need to do more. Hopefully tomorrow I can show what I am talking about.
RVZIOi
Old Mar 19, 2018 | 09:39 AM
  #445
NAVY08's Avatar
NAVY08
Not much to report as I am still not with the car, however I did make a parts purchase:
Not the most exciting purchase, but its all one step closer, right?
Parking brake cables for both C5 and C3... not sure which will be needed, but at $15 bucks each, I'd rather have both than the wrong one.
Parking brake shoes and hardware
Timken hubs for all 4 corners
I've been doing lots of research, I cant wait to get home and get back to work!
Old Mar 22, 2018 | 09:47 AM
  #446
NAVY08's Avatar
NAVY08
The first set of projects I will be tackling when I get back is working on the rolling chassis. Replacing bushings, ball joints, and working on the brakes. I am making a list of tools I want to pick up when I get back.
50 Ton Shop Press
Eastwood Powdercoat Setup
Eastwood Brake Flaring Tool
Eastwood Brake Tubing bender
Inline Air Sander
3in Air Polisher
I am on the fence to purchase these, or just use the tool loaner program from Autozone...
OEM Tools bushing driver set
OEM Tools Ball Joint Adapter Set
What are your other "goto" specialty tools that you cant do without for your project?
I really want a Gantry Crane - but I'm not sure I will use it often enough to justify the expense...
Anyone have any luck pulling a body with a regular engine hoist?
Old Mar 22, 2018 | 02:26 PM
  #447
gleninsandiego's Avatar
gleninsandiego
I did.
And I used the sling available from the usual vendors
The big problem is the length of the sling straps
The straps are too long
They would be great on a gantry but the engine hoist doesn't lift high enough.
We ended up tying knots in the straps to make them shorter but
they were not the same length and thus the car wasn't perfectly level when it came off the frame or going onto the dolly
If i were to do it again I would have the straps shortened professionally
After we did all the body work on the dolly I didn't want to risk messing it up on the install. I was pondering renting a gantry but we ended up having use of a two post lift and actually cutting the sling straps and wrapping them individually around the lift post supports (see my build thread - Glenn's reluctant body off)
There are also examples on you tube of people doing it with a engine hoist
Old Mar 22, 2018 | 03:16 PM
  #448
NAVY08's Avatar
NAVY08
Originally Posted by gwgwgw
I did.
I have that same sling - and I had the same issue taking the body off. I wasn't overly concerned taking the body off with all the fiberglass repair my body needed - however once the body work is done, I don't want to half a$$ it going back on.
I hadn't checked youtube yet - good idea, I'll look there.
If I do get a gantry... what other uses is it good for other than the body lift and engine installs?
Old Mar 27, 2018 | 06:59 AM
  #449
NAVY08's Avatar
NAVY08
I have been doing some research on body rotisserie setups for completing the work on the under body of the car and the replacement for the rear floor. I first came across a setup using two Engine Stands:
I then saw a version made out of wood, which is a bit, well less refined, but was ingenious!
Red Neck Rotisserie
What do you guys think? Any more Crazy that a wooden body cart?
Old Mar 29, 2018 | 10:14 AM
  #450
NAVY08's Avatar
NAVY08
Old Mar 29, 2018 | 11:32 PM
  #451
jr73's Avatar
jr73
The car doesn't know its on a wooden rotisserie, and it will let you do what you need to do.
Old Mar 29, 2018 | 11:47 PM
  #452
gleninsandiego
For some reason I am a bit uneasy thinking about putting a vette body on a rotisserie. I say that because how fragile my front clip seemed to be when I had the body off the frame. I have done three rotisserie restorations, one using the engine stands. I borrowed them from a friend and it was so flimsy that it flexed and the body fell off the stand when it was upside down and crushed the roof.
All the others were done on a professional rotisserie at my body shop. It was a joy to use so I see the attraction. But the key is how you mount the car to the stand. On a metal car you attach to the bumper brackets, but with a corvette with the body off, I am not so sure the birdcage is strong enough to handle everything. I have no solid experience to back that up. Just wondering
Glenn
Old Mar 31, 2018 | 01:11 PM
  #453
NAVY08's Avatar
NAVY08
Glenn
Great point, Glenn - But I will be doing this before I bond the front clip back on. I will probably have to fugure a way to support the top of the birdcage too. I will think about it!
Old Mar 31, 2018 | 01:18 PM
  #454
NAVY08's Avatar
NAVY08
Got another batch of photos in from by body guy!
Goodbye Antenna!
Good-bye Luggage Rack!
Old Mar 31, 2018 | 01:31 PM
  #455
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Ahhhhhhh......a smooth rear deck will look good!
Old Mar 31, 2018 | 01:54 PM
  #456
gleninsandiego
Ah....sounds good
Also to clarify, the 3 rotisserie restorations I did previously were no on corvettes, they were on metal unibody cars.
The pics above are great
Progress!!!!
Glenn in San Diego
Old Mar 31, 2018 | 04:21 PM
  #457
Tim 1973's Avatar
Tim 1973
I have mine on a rotessary, you have to have a solid frame not like a metal car and it also Locke’s in the front.
To Bob's 1969 Resto-Mod Build Thread
Old Mar 31, 2018 | 05:43 PM
  #458
brent319's Avatar
brent319
C3 of Year Winner (appearance mods) 2019
does that two engine stand set up allow for setting the balance of the car on the stand
so it is not top heavy ?
Old Mar 31, 2018 | 07:19 PM
  #459
gleninsandiego
Very impressive
Old Mar 31, 2018 | 09:37 PM
  #460
Tim 1973's Avatar
Tim 1973
Very impressive
Shops a mess but I was working on it when I sent the post.....
Tim
