Headlights Stopped Working
Old Sep 5, 2015 | 02:26 PM
lentze's Avatar
lentze
Default Headlights Stopped Working
Hello,
I have a 1970 and the headlights on it stopped working one after another recently. The bulbs look fine, the fuse is still intact.
One weird thing is when I short out the connector wires on the back of the right outer bulb it lights up. I am shorting the outer wire with the center wire, not sure what that means though - maybe need to put in a new connector, or better off with a new bulb?
The right inner bulb only has two prongs and wont turn on when shorted. These bulbs could be 15 + years old.
Any ideas?
Thanks!
Old Sep 6, 2015 | 08:08 AM
Alan 71's Avatar
Alan 71
Hi L,
Because of the bulbs' age and your description of what's happened I think I'd start with some new bulbs.
Your 71 headlights have 'fiber optic' connections too; so be aware of that when you change the bulbs.
Good Luck!
Regards,
Alan
Old Sep 6, 2015 | 08:18 AM
65GGvert's Avatar
65GGvert
The headlights don't have a fuse, they have a circuit breaker built into the headlight switch. If they did stop working one at a time as you said, you should start by checking the connections both at the bulbs and follow the wires back to where they split on the driver's side connector to go to the passenger side. You may have more than one problem, like a mix of good and bad bulbs AND a bad connection, or an intermittent dimmer switch confusing the issue.
Old Sep 12, 2015 | 04:06 PM
lentze's Avatar
lentze
Thanks - looks like I got a bit of troubleshooting to do!
Old Sep 12, 2015 | 10:05 PM
bj1k's Avatar
bj1k
I've seen dimmer switches react this way and they are so cheap for these cars that it is a no-brainer to start there and just replace it especially considering the age .
Old Sep 19, 2015 | 07:44 PM
lentze's Avatar
lentze
I just replaced all bulbs and the outer ones work now. Should I still try replacing that dimmer switch to see if it lights up the inner bulbs?
- also - where is that dimmer switch, in the engine bay or part of the actual pull out switch in the dash?
Thanks!
Old Sep 19, 2015 | 08:30 PM
65GGvert's Avatar
65GGvert
Thanks!
You don't know where the dimmer switch is for the headlights? To switch from bright to dim? If not you may not have any problem, you just haven't dimmed/brightened your lights. It's on the floor, under the carpet, by the kick panel. One stomp for bright, another stomp for dim. All four lamps work on bright, only the outer two work on dim.
Old Sep 19, 2015 | 08:37 PM
Iceaxe's Avatar
Iceaxe
The dimmer switch in your car is located under the carpet to the left of the clutch pedal (or where the clutch would be in an auto). The switch costs less than $6 and takes 10 minutes to change. It's really simple as it's just two screws and a plug. The switches are proven to failure being mounted on the floor as they would get moisture in them. Replacing a floor mounted dimmer switch is the first thing I do with any car having headlight issues. If the switch is old it's probably time to replace it anyways.
Old Sep 19, 2015 | 08:52 PM
65GGvert's Avatar
65GGvert
But FIRST, step on the dimmer and change the lights to bright. The inner bulbs are not intended to light in the dim position. You may have already fixed the problem.
Old Sep 19, 2015 | 08:58 PM
'75's Avatar
'75
Seems like you have the low beams turned on, and when you short the terminals on the rear of the bulb, you are connecting to a good filament, so there is apparently power there. The center lights (high beam) only have one filament, thus only 2 connections. Outer lights have 2 filaments, one terminal for ground, one for high and one for low beam.
lentze's Avatar
lentze
You know - as soon as I read this I slapped myself in the head! I had totally forgotten about that switch in the carpet (in my defense it has been about 12 years since I last drove/fixed the car).
Haha! Anyways thanks for that - it all works now! Just got to get to a few cracked vacuum lines for the left set and should be done with that job.
Thanks!
Old Sep 19, 2015 | 09:25 PM
65GGvert's Avatar
65GGvert
Fantastic, I love a happy ending.
To Headlights Stopped Working
