Trans Tunnel Insulation
Old Nov 14, 2015 | 07:05 AM
AdamMeh's Avatar
AdamMeh
Default Trans Tunnel Insulation
Is is possible to install this with the trans in the car? Our '77 is a 4-speed if that helps.
Would I need to resort to an alternate method of attaching it due to limited space?
Adam
Old Nov 14, 2015 | 08:30 AM
Alan 71's Avatar
Alan 71
Hi Adam,
Yes, but also maybe!?!
There is VERY little room between the transmission and underside of the transmission tunnel.
If I were doing it I would resort to cutting the insulation crosswise into 4 or 5 strips/pieces which could the be worked/forced into position individually.
I'd then try to seal the cuts back up using the silver duct tape that's actually used on hvac duct work.
Keeping it in place won't be a problem… it'll be TIGHT in there.
Good Luck!
Regards,
Alan
Old Nov 14, 2015 | 10:56 AM
Wee's Avatar
Wee
I did it with just one cut...But it didn't fit in there like I wanted it to....Better than having nothing and I will replace it the right way if or should I say when I have to drop the trans.
Brian
Old Nov 14, 2015 | 11:00 AM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
I was able to get it installed by splitting it down the center and sliding each half up around the Tremec. So I imagine if you have a muncie 4sp it should work just fine. I also sprayed the back of the pieces with 3m adhesive at time of final placement.
Old Nov 14, 2015 | 12:26 PM
AdamMeh's Avatar
AdamMeh
Excellent ideas from all - thanks very much guys! This seems like an achievable goal without breaking the bank, and any help with interior heat would be a good thing.
Adam
Old May 13, 2016 | 11:28 AM
Richard Daugird's Avatar
Richard Daugird
So Adam did it work?
Old May 13, 2016 | 02:12 PM
AdamMeh's Avatar
AdamMeh
Hi Richard,
I have not tackled this project yet. The car has been on hold due to life circumstances. Not forgotten, just on temporary hold.
Old May 13, 2016 | 02:29 PM
Richard Daugird
I think a lot of us can relate to that. I have yet to drive mine in really hot weather but I cringe, because it gets REALLY HOT down here on the Gulf Coast.
Old May 13, 2016 | 05:22 PM
AdamMeh's Avatar
AdamMeh
I hear you... getting stupid hot here in Phoenix as well. The summer months don't allow for much driving time unless you have AC, which we don't (yet).
Old May 13, 2016 | 05:42 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
On a 4 speed, without taking the shifter out of the car the only way is to split it.
When you install it watch out for those retaining tabs.... They can bite...
When we install them by splitting them in half we use the foil tape with some wildwood glue to connect the two halves together. It won't show up that bad if you do this.
To Trans Tunnel Insulation
