Just got done lowering the body onto the restored frame and it appears to be sitting very high. I replaced all of the body mount bushings with poly and in this photo non of them are tightened yet. I know it may take some time for the new bushings to settle and that the added weight of the interior may lower the car some but, for those of you who have done a frame off resto, does this look right?
I just looked at a 75 in my shop without rocker moldings and the space between the bottom of the sill and the bottom of the frame looks about the same as yours, so I don't think the new poly mounts are entirely to blame. Also, your car is missing a lot of items which will add a lot of weight (glass, bumpers, tops, interior, radiator, etc.) That said, as ddawson mentioned, it is imperative that ALL suspension pivot points remain loose until all weight is back on the car. Not only will this allow the car to settle properly, it will prevent damage or premature failure of the rubber bushings due to excessive torsional movement. I made this mistake on my car and and had severely cracked control arm bushings within a few years and less than 10K miles. Chip.
Looks about right for where you are in the build and what you have and don't have on the car.
ZIO
Hi SO,
It really takes every bit of the car's completed weight plus some gas to get the car to settle to it's proper ride height.
Certainly changing bushings and springs can affect what the ride height will be, but it's too early to tell in your case.
Regards,
Alan
Once you get the motor and transmission installed, she'll settle in. Even once this is complete, if she looks a little high, don't freak out. She WILL settle down, Once my car was complete, I felt the very same way, and was after everything was in. It took a few weeks, and she settled in, right at about an inch lower than the factory springs in the front.
My 78 looks exactly like yours. Now I can relax knowing that it wsan't something I did ( I hope). My specific parts are loose, no interior, no engine or trans and new springs so I am hoping that it will settle down once everything is in place and I can drive around the block a few times. FYI, I put pieces of green masksing tape on all the fasteners that need to be loose until I can drive the car and settle it down. SO as long as I can remember WHY I put the tape there, I will be OK. Yours does too.
Replaced all rubber on the chassis with poly and the control arms are still loose.
Thanks. Will have to re-check the suspension pivot points. We did the chassis so long ago I don't remember if we left them all loose.
Motor and tranny are in. I'm hoping that it will settle down once all of the remaining parts are installed. Thanks for all the replies. My mind is eased somewhat but I'm still skeptical. Time will tell I guess.
Somethings seriously amiss. The weight of the doors, interior pieces and other misc parts weigh less than 500 pounds. That weight will settle the car less than 1/2 inch-four spring points at 400 (approximately) pounds per inch.
YES...the reason you feel that there is something 'seriously amiss'...is because there is a LOT MORE off the car than what you wrote. No radiator and the 3-4 gallons of coolant mix, A/C compressor or all of the front impact structure...which is heavy...the headlight assemblies, glass, the complete door assemblies...because when they are fully dressed...the doors with the impact bars in them are HEAVY....NO wiper assemblies... SO..he is fine. Only because I have seen this 'look' at my shop numerous times. IT will go down further...I will BET on it. With all that still needs to go on the car...these parts are WAY over 500 lbs....and that is due to only commenting on what can be seen in the photo he posted at that angle.
