The Corvette has been the only car I’ve worked on where “ special tools” were required.
(i.e. the spindle bearing set up tool) the kit was 300 bucks.
Paying someone to do this ( like Gary R.) would cost as much, if not more, and there’s shipping back and forth to add to that. The difference is I still have a way to do it again should I ever need to, only this time it’s free.
I have three boxes sitting on bases full of tools,…some of the stuff I haven’t touched in years. I guess it could be argued that it should be sold off as opposed to just sitting around taking up space. And while I concur, it doesn’t matter whether it’s the US or Canada, mechanics tools are in every pawn shop and flea market all over the place, and are potentially worthless to anyone except me.
And even if I garage-sold the stuff I haven’t touched in a decade,…took .25 to the dollar, right after I sold them, It’d be the one I need next.
I guess the stuff will just have to sit and take up space.
I agree, doing a job yourself and buying an expensive specialty tool to do it instead of paying a shop to do it can pay for itself in one job. In my younger days I bought some fairly pricey specialty tools to work on a single job and I figure I saved enough doing it myself to pay for the tool.
Then there's the tools people borrow from you because they're just starting out and can't afford much, they break it and then put the broken pieces back on your tool box and say nothing, or they lose your tool or part of a tool that can't be used without that part and won't pay you for it, or a tool the shop should really be buying for general use you end up buying for yourself because the owner doesn't want to spend the money. One time my husband bought this specialty tool and had yet to use it before the shop started using it to do some fairly regular job they would get in. It wasn't meant for the kind of work they were using it for and the shop really needed to buy the correct tool to do that job. After several of those jobs they destroyed it because it wasn't exactly right for the job but you could make it work in a clumsy way. The owner wouldn't pay for a replacement.
I feel for your hubby. I have had three hernia's from my past work in maintenance in an automotive parts plant. The longer that you stand , the worse the pain gets. It is no fun having one. Lou.
Those 20 year old tools probably have more use left in them than the new China made stuff that you get one or two uses out of then throw away and have to buy a new one.
My 40 year old Skil 1/2” hammer drill finally gave out on me a few weeks ago while I was drilling into a concrete slab for anchors for a new shed.
My heart was broken, because I’ve had it forever, but especially because I know anything new on the market, even a new Skil won’t hold up like my old one.
I'm sure my husband would agree with you. In my 20's I had gone through around 3 black and decker drills. I went into a store selling used tools, bought a used Makita drill and 30 years later I'm still using the same drill.
Originally Posted by 7t9l82
I wonder if there's a way to deduct depreciation? Seems like there should be an angle somewhere.
I'm sure if there was a way it would be generally known amongst mechanics and he would know how to do it. It seems unreasonable that you can't.
I don't know if you are aware but only 1/4 (or less) to at most 1/3 of the cost of an hour of labour you pay to the repair shop to fix your car goes to the mechanic doing the work.
i fixed copiers for 30 years, they charge cust 5 times what they pay the techs. but by his own admission he made a LOT more when using those tools than he does now while using a phone and a parts counter. he needs to go through the stuff. the tools that are for working on specific vehicles that are nearly extinct are also extinct. they are worth more as scrap metal than they are as wheel chocks. also, all those tools makes it impossible to use any of them except for the 3 months you can work outside. only other possibility is buy a car needing the specialized work some of those tools are needed for. and that is right back to being a mechanic. AND a used car salesman!
Certainly he made a lot more with the tools than he would have without, to us it just seems reasonable that you would be able to deduct the cost from your gross income as they aren't for personal use and you can't do your job without them. If I remember correctly, the business owner can deduct the cost of tools the shop buys for general usage from the business's gross income.
If it's legal in your area, he could get a business license and perform diagnostic work only (to avoid worsening his med. condition).
The customer could buy the needed parts and DIY. Maybe there would be a TOOL tax deduction if he took that route?
He had talked about doing something along those lines several months ago but I haven't heard him mention it since. I would think likely in that situation he could deduct tools from his income, although I kind of doubt he could deduct any of the tools he's already bought.
I should have made it clear, the spouse has not retired unfortunately, we can't afford that yet. He's taken a job as a parts man as the car repair is too physically demanding, he has an untreated hernia that's only been getting worse and says he can't see well enough to see the pin-outs on wire connectors. Another 4 years planned before he retires and it's at about half the pay he was getting. In the mean time he says I'm not allowed to use his tools as I'm pretty haphazard and disorganized and he's afraid (with some justification) that I'll lose them.
Is it a inguinal hernia? If so, don't put off getting it repaired.
I don't know, I'm super squeamish so I don't like to go into detail on this sort of thing. He's had it for as long as I remember but he did say it was getting worse. The doctor is looking at it and I presume now that he's not working as a mechanic he'll take the time to get it repaired.
my dad gave himself a hernia at 82. pulling a kayak out of the water full of water. doc wouldn't operate cuz he knew surgery was worse than the hernia. for 3 years. then he had to get the surgery. then he wouldn't listen to the pros and stay in rehab and not move and heal. then he died. he was 86. not like he died young. moral of story. if he gets the surgery DO NOT LET HIM DO ONE GODDAMN THING if the therapist, nurses, etc tell him "don't do that!" this is his middle. his trunk. the muscles surrounding his organs. they have to heal completely and you heal slower the older you get. a lot of us wish our wives liked these cars better than they do. but we don't want you put back in running that way. besides, you are too far north...
Good advice, I had my hernia surgery 4/1/2021 at age 70. Spent 10 days in the hospital due to complications, but now I'm doing fine. I was on light duty (my wife wouldn't let me do anything) for 5 months.
Glad I followed her and the surgeons orders!
I had this little lump for over 20 years.
3 years ago it decided to become a little sore that just never healed, so I went to the doctor a couple of weeks ago.
The doctor asked me why I waited so long.
I just had surgery Wednesday after they found it was a cancerous growth.
They cut out a huge chunk of tissue the diameter of a golf ball.
I’m going nuts because I can’t do anything.
I can’t sit for any time, I can stand for a while, walking is uncomfortable, and going from standing to sitting takes forever because I don’t want to pull the stitches.
Have hubby get it done, before things become complicated.
Yes, I'll ask him about it and encourage him to move it along if he can. I'm sorry to hear about your cancer diagnosis. I hope follow up treatment goes well for you.
Thanks Priya.
I actually received a call from the surgeon Friday.
He said the pathology report was good and they were able to remove all the cancerous tissue.
So no issues going forward.
I don’t drink, but Kristine and I had a glass of champagne.
Ok, maybe two!
hey, i just had a thought. as soon as he goes into hospital, toss out all the junk and outdated tools. when he is finally back up on his feet, just remember eddie murphy's line... "wasn't me!"
Now there's a thought! Actually I'd have very little idea what is junk and outdated and what isn't. We went out to the garage yesterday and he set to finding places for all the stuff on the hoist (I guess I was there mostly for moral support) and damned if he didn't find places for it all. He's so much more organized than me, the garage didn't look appreciably different after he found places for all that stuff, it was kind of like magic. So now I have to motivate myself to get back into the swing of things. Probably not today, but hopefully soon
