Dynamat
Old Dec 5, 2015 | 11:41 PM
gdh's Avatar
gdh
The Blockit Deadmats with the mlv looks to be very similar to what we've used in recording studios with the multiple different density layers.
Old Dec 6, 2015 | 08:41 AM
minitech's Avatar
minitech
I think the best way is Dynamat (Or similar product) down first and then Frost King (Or similar product) on top of that.
The butyl rubber with aluminum backing helps with vibration and helps the car to be quiet and the foam/aluminum is made to block heat.
Why not do both while you have it apart?
Frost King or Reflectix are made to be put right over heating ducts to keep heat in and works to keep heat out of the cabin.
Very best way though is to put a heat barrier on the bottom to keep the heat from even getting to the panels like the space shuttle. But you would need to take the body off to do a complete job of that.
Old Dec 6, 2015 | 01:07 PM
Sunstroked's Avatar
Sunstroked
As mentioned, I wanted to do this job once. With my interior gutted, I used Dynaliner extreme, followed by 1/4" Dynaliner.
I would say it was worth the expense and effort.
Old Dec 6, 2015 | 06:05 PM
DUB's Avatar
DUB
Originally Posted by Peterbuilt
Anyone not insulate behind the seats? Does it get hot back there?
I do from time to time if the owner wants to do it. The radiant heat is not that excessive...as like up at the firewall area.
But if you want the car quiet...I do install behind the seats and over the rear wheel tubs.
DUB
Old Dec 6, 2015 | 08:56 PM
7T1vette's Avatar
7T1vette
The heat insulation in the storage area is pretty much a waste of effort. There's not a lot of heat that gathers under that area....unless the engine is on and idling for quite a while.
That is a good area for sound deadener, though.
Old Dec 7, 2015 | 06:54 AM
Lobzila's Avatar
Lobzila
If you have gutted your interior, double down on your insulation. I put down a layer of the Ceramic Lizzard skin, and then a dyno-mat type material on top of that. No fitment problems when the carpet went back in and heat is not an issue. However, my sidepipes are still pretty loud.
Old Dec 7, 2015 | 08:10 AM
Street Rat's Avatar
Street Rat
Love the avatar Lobzila!
