First engine pull!! Now what to do??
Old Dec 8, 2015 | 06:03 PM
  #41
DUB's Avatar
DUB
Originally Posted by USA-OSC
Just a quick question, are the alignment problems encountered when trying to mate the input shaft with the clutch inherit with most GM cars or just the Corvettes? When I was playing with Fords I never had a problem pulling and installing the motor only. Just in case I decide to pull my motor. Thanks, sorry for the hijacking.
I knwo many people choose to pull an engine that has the clutch attached and re-install it. FINE BY ME...NOT something I have to worry about or warranty.
BUT...coming from a person who does this....I prefer to make sure that when I am sliding the transmission in place...I AM in CONTROL OF IT...AND I do have transmission jack and the tools to make sure I 'probably' could install the engine with the clutch attached WHILE the transmission is still in the car....BUT I DON"T.
The reason is like many may know....that damaging the pilot bearing and or having the transmission input shaft 'tweak' the clutch disc due to not going in just right can cause for a 'possible' problem that MAY cause it to be taken back apart again.
DUB
Old Dec 10, 2015 | 10:52 PM
  #42
Mattrv73's Avatar
Mattrv73
Update...
I let my wife read some of the comments posted by the "experts" and "pros" and "seasoned veterans" and she agreed to increase the budgeted amount.
oh happy days are here again....
Old Dec 10, 2015 | 11:19 PM
  #43
Majoho's Avatar
Majoho
Originally Posted by Mattrv73
Update...
Ain't the forum GREAT!
Old Dec 11, 2015 | 08:18 AM
  #44
929nitro's Avatar
929nitro
Sounds like you have a good one. Trying to keep a low budget but realistic when given the facts.
Old Dec 11, 2015 | 10:24 AM
  #45
74Ken's Avatar
74Ken
ok, keep the CFO.
lol
Old Dec 11, 2015 | 06:55 PM
  #46
DUB's Avatar
DUB
Update...
Isn't it GREAT to have someone who can draw a new conclusion when presented information that they may not have considered.
I am sure that even with an increases budget....I KNOW you will apply these increased funds in the correct way.
For what it is worth to you...because I deal with project quite often and have a budget from the customer in most cases. One thing I do is FOCUS on a specific area FIRST and make sure the repairs are going to meet the expectations of the owner....and NOT worry about other areas.
I think of it like this. You are wanting to build a three story castle out of stone. And you have 'x' dollars to build it and furnish it. I would be more concerned that the money needed to get the foundation of the castle is RIGHT....regardless of what it took...and not be so concerned if I took ALL the money allotted for the drapes in the house.
It is so easy to sacrifice money in important areas...only to find that this can come back and haunt you. Only replying from FIRST HAND experience on that.
DUB
Old Dec 12, 2015 | 06:33 PM
  #47
Mattrv73's Avatar
Mattrv73
1. Started to wirewheel some of the metal parts today.
2. Put a down payment on a 383 stroker yesterday.
3. Buying front end suspension Moog parts on eBay when they are cheap.
Feeling not so overwhelmed because of the great comments from members on this forum who totally screwed up before me and doesnt mind letting everybody know.
Thanks!!
Old Dec 13, 2015 | 07:38 PM
  #48
ttoptom1's Avatar
ttoptom1
Thanks!!
Had Worrall's in Clarksville do my short block a few tears ago and very pleased with results. Don't remember price but think very reasonable.Don't forget about Ernie and Tommy at Willcox. They can be very helpful with everything you'd encounter!
Old Dec 17, 2015 | 08:55 PM
  #49
bj1k's Avatar
bj1k
Originally Posted by DUB
Just my opinion for a person who is doing this for the fist time.
Be prepared to remove the transmission. The reason being....getting the engine out is one thing.....trying to get the clutch disc to PERFECTLY index to the input shaft of the transmission is another thing ENTIRELY. DAMAGE TO NEW PARTS CAN RESULT!!!!
I have been doing this stuff for 30 years and I personally prefer to have the engine and transmission joined when it is hanging from my chain hoist and then put BOTH in at the same time...using an engine tilter attached to the engine.
It depends on what you want when you get done....in regards to how good your engine compartment looks, etc. We do not knwo that...so advising you to do 'this and that' may not be a concern to you and a waste of time providing our personal thoughts Knowing what you want to achieve helps greatly.
Be prepared to obtain some tools to aid you in doing the front suspension IF....repeat ...IF you plan on doing the front suspension when the engine is out of the car. That is IF you are concerned about safety. ( just my opinion on that).
Using a used LT1...which I am assuming is NOT the fuel injected LT1....hopefully goes GREAT for you. I know that there are good used engines...ESPECIALLY if you can hear it run and check it out before it is pulled......but there are ones that could be a 'thorn in your side' also. JUST being realistic. Because I have encountered this when people bring me used engines expecting me to perform 'miracles' to it when sometimes I can not do it because there are internal problems that I can not put a 'Band-aid' on and send out the door.
DUB
I agree that for someone with limited experience and limited tools and equipment it is easier to pull the engine and transmission and install it as a unit but I have always just pulled the engine if there was no problem with the transmission. I just pulled the engine in my 72 4 speed Corvette last week to do an engine swap and I left the transmission in it and just pulled the engine with the bell housing and clutch assembly attached . I installed the clutch assembly with a clutch alignment tool and installed the bell housing on the new engine ,installed an engine tilter so I could drop it in on an angle to the transmission which was also jacked up on the front to match the angle that the engine was going in and everything slid right together and I did all of this without a helper to align things. It took all of 20 minutes to connect everything to the transmission. It's not hard if you take your time and it saves having to take the shifter out ,transmission and driveshaft.
Old Apr 30, 2016 | 08:02 PM
  #50
Mattrv73's Avatar
Mattrv73
Default Updated Progress
The 383 that's going in my Vette. Soon I hope....
Engine compartment clean up is not fun nor easy.
