t top alignment
There are 4 points at which the panels are adjusted.
Front outer corner 'guide pin'. There are 2 twelve point bolts that allow movement/adjustment of the pin.
Rear outer corner triangle wedge. The wedge threads in and out of it's mounting place for forward and rearward panel adjustment. The 2 screws in the plate allow the plate and wedge to move up and down so the panel moves up and down.
2 center lock wedges. These wedges can be shimmed to move the roof panel up and down and slid to allow center gap alignment.
All 4 adjustments should be loose to begin with when adjusting the panels for fit and gap alignment.
It's not easy but IS doable.
Regards,
Alan
Front outer corner guide pin showing 2 mounting bolts.
Tri-angle wedge and adjustment screws.
Forward of the two center lock wedges with shims in place.
Regards,
Alan
Regards,
Alan
I been thinking about this issue too.
