How bad can it fit!
I have bought alot of new things from corevtte central and others.
But everything i´m mounting fits like crap.
For example i mounted new front bumber outer brackets with new extensions.
I don´t know if the bracket or the extension was to long but i had to cut 20mm and reweld the extension, this is new stuff!
I also bought a new handbrake console and shifter console.
I got the shifter console in place with alot of force! i wanted it longer in but it isn´t possible(maybe with a crowbar
)The handbrake console fits bad aswell and the small plate that you should fit in the console doesn´t fit at all just vobbling around in there.
This goes on and on on every new part i´m installing.
Can´t be just me with these problems.
Or maybe people is used to work with this very bad quality?
Took a couple of Pictures.
There is quite a bit of front/rear adjustment on the bumper bracket where it bolts to the frame extension and where the extension bolts to the frame.
Did you look to see if you could get some help there?
Regards,
Alan
It looks like your console are 'spread' too. How much padding and carpet are under them, and how far up the sides of the tunnel does it extend?
The amount of space you have to install the shifter console and e-brake console depends entirely on how the center gauge bezel is mounted in the dash pads.
If the bezel is 'tipped' too much or allowed to drop down even a little bit it limits the space for the 2 consoles because of the seat bulkhead at the rear is a fixed point.
I think you shifter console needs to be slid forward and up at it's front which will give the extra 3/8" in it looks like you need to seat the e-brake console.
Interiors are NOT easy under the best of circumstances.
Regards,
Alan
Hi Allan and thanks for taking your time.
I have adjusted it as far back i can, regardless what i did i had to cut the extender, probaly something wrong with the parts, i don´t Think the car has been thrinking
Regards,
Alan
The small piece in the end of the console seems mounted in the shifter console?.
If i do that the "linecover" for the handbrake doesn´t pas.
I can´t get the shifter console further front because it sits against the spedometer console, i doesn´t dare to push the shifter console any harder against that speedo console.
The shifter console was way of from the origanal mounting holes in the car!!
As i said i need to get it more forward but that i very hard!
Regards,
Alan
My big question to Alan is - Do you take things apart to take pictures for each question you answer or is your file that HUGE?? And if your file is that huge, how do you remember and keep track of where everything is? You are AMAZING my friend!
Reproduction parts for '55 - '57 Chevys are even worse.
I think part of your situation might be caused by having some of the dash parts screwed tightly in place while installing others.
The center gauge cluster must be free to move forward and backward while the shifter console and e-brake console are installed.
It's the length of the 2 consoles combined that determine the position of the bottom of the center gauge bezel and lower inner corners of the dash pads.
I looked at pictures of several reproduction shifter consoles and they appear to have the tilted lip you mention.
Has your's been cut off?
How about a couple of pictures of the fit of the front of the shifter console at the gauge bezel and dash pads? I think that's were your trouble begins.
Regards,
Alan
There are now about 8500 pictures and the number is growing by about 1000 per year.
Since I took all of them I can immediately know if I have one to use for a member's question.
I have them divided up in such a way that I can find what I'm looking for pretty quickly.
Since I continue to tinker with my car I continue to have opportunities to take pictures of things I don't presently have.
I do take new pictures to specifically use in a reply when it's possible. For instance a couple of the pics for this thread were old and a couple were new.
Regards,
Alan
Regards,
Alan
I have the spedo dash fitted with only 2 screws, i have now got the shifter console more forward, regardless the handbrake console fits pretty bad, the problem is the shifter console is to fat where the handbrake console going over, Will take a couple of pictures of that.
On my 68 I had every bolt/screw very loose from the parking brake cover to the wiper switch and after a lengthy time of wiggling and pushing and incremental tightening of fasteners did I get everything to fit at a acceptable level
The 'spread' is why I asked about the carpet and underlayment.
If it extends too far up the sides of the tunnel it cause the consoles to spread.
I installed the consoles before trimming the carpet and padding. I left it so only about 1" of the carpet extends up under the console sides.
You can see that in this pic.
I continued to cut the carpet so it followed the line of the bottom edge of the console on each side.
I hadn't cut for the e-brake console yet in the pic.
I put the e-brake console back where I wanted it to sit, marked the carpet, removed the console, cut the carpet, and then put the console back in place.
Note in this picture that you have to be careful how much you cut at the very rear of the footwell carpet on the tunnel so that the rear bulkhead carpet covers the cut edge. If you cut too much there'll be a gap between the two.
Regards,
Alan
Note it only extends about 1" under the console side.
