retro fitting/replacing stock power window switch's
Old Jan 21, 2016 | 05:20 PM
Lyndwood's Avatar
Lyndwood
Default retro fitting/replacing stock power window switch's
I have to replace old original power window switches in my 74, I took them apart & cleaned them as instructed on other posts & they still don't work + one case is cracked. I am not doing a restoration & the cars not original anyway so I was wondering if there are any other options for replacement. Can I retro fit an aftermarket (newer) style into my center console & if so what has anyone else used with success. I have read that the newer repop vette switches suck(?) so I thought I could use another GM style switch & just adapt the wiring & new switch to the console to fit .
any thoughts on the matter?
Old Jan 21, 2016 | 05:27 PM
EIGHTY's Avatar
EIGHTY
I agree that the new switches are below average. Mine making a popping noise when putting the windows up. I also had to glue one of them back together after the case fell off.
Old Jan 21, 2016 | 09:52 PM
Richard454's Avatar
Richard454
Here's a great thread on it-by "Mooser"
https://www.corvetteforum.com/forums...-finished.html
Or you can add some relays and keep the new ones made by Chinese kids from burning up- for reference only the right side upgrade is shown-
Old Jan 21, 2016 | 09:55 PM
bj1k's Avatar
bj1k
I can only suggest if you know a wrecking yard somewhere that you will be permitted to browse through some GM cars with power windows you might be able to match one that will be close. I had a 67 corvette that needed a switch for opening the headlight doors and didn't want to pay the $100. that the corvette dealers wanted . I found a switch that I could adapt out of a Pontiac for $5.00 . I made a wiring adapter so I didn't have to alter the original 67 wiring. It worked great .
To retro fitting/replacing stock power window switch's
