vapor cannister
Old Jan 29, 2016 | 11:23 PM
Omarsvette's Avatar
Omarsvette
Default vapor cannister
the only replacement i see on eBay have two ports. my 73 has three ports with a valve. can i use the other and not use the valve? what the valve for?
Old Jan 30, 2016 | 08:10 AM
Alan 71's Avatar
Alan 71
Hi O,
The function of the valve is to open when the car is being driven. This pulls air through the charcoal in the the canister which pulls the gasoline vapor stored in the charcoal into the carburetor to be burned. The process is called 'purging'.
When the engine isn't running the valve closes to prevent the escape of any gasoline vapors in the canister which could lead to you smelling gasoline in your garage.
Many people have removed these systems so a used 3 port canister can be found if you so desire.
Regards,
Alan
This canister is from a 71 car.
Old Jan 30, 2016 | 10:07 AM
Omarsvette's Avatar
Omarsvette
thanks
Old Jan 30, 2016 | 11:00 AM
7T1vette's Avatar
7T1vette
The primary purpose of that valve is to prevent excess air getting into the fuel/air mix at IDLE conditon. The valve is hooked to a "timed" vacuum port on the carb, so that it closes when the throttle plates are closed (but open when the plates open up).
Otherwise, you would get erratic engine idle behavior.
Old Jan 31, 2016 | 06:07 PM
rdroket's Avatar
rdroket
So can this canister be eliminated and if so what do you do with the vacuum line from the gas tank?
Old Jan 31, 2016 | 07:01 PM
mortgageguy's Avatar
mortgageguy
May I suggest you rebuild your cannnister? Google it. Go to Petsmart, purchase aquarium charcoal and filter material. It's a simple process that totally renews your original cannnister. There are very clear instructions on the net, with pictures.
Old Feb 1, 2016 | 05:06 AM
7T1vette's Avatar
7T1vette
You could remove it, but a working canister has a useful purpose and no real downside. Be aware that the vapor canister is the "fuel tank vent" for a car so equipped. If you remove it, you need to install a vented gas cap.
Old Feb 1, 2016 | 04:50 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
And a vented garage/LOL.....on a 98*F day my wiff/wife detects gas fume odors after I park the Vette
Old Feb 1, 2016 | 05:11 PM
7T1vette's Avatar
7T1vette
Either your canister is not working properly, or the activated-carbon material in it no longer functions...or someone has wrongly installed a vented cap on your fuel tank. There are some other possibilities that involve the hoses going to the canister and/or the little 'separator' unit at the top of the fuel tank where the vapor hose is connected, also.
Exchanging the carbon material in the vapor canister is not "difficult"...but it does take a bit of work. If the vacuum switch at the top of the canister is defective, the canister likely needs to be replaced. And, if the canister is defective, you could just plug up the line coming from the fuel tank and install a vented fuel cap. The rest of the system will cause no operating problem.
P.S. Fuel fumes can also be caused by pinhole leaks in the fuel tank and/or deteriorating hoses connected to the tank.
To vapor cannister
