upper hose
Old Mar 9, 2016 | 07:02 PM
terry82's Avatar
terry82
Default upper hose
I checked under the hood today and my upper hose is collapsed.it was replaced a few years ago.Can you find the ac delco hoses ?
Old Mar 9, 2016 | 08:45 PM
Ironcross's Avatar
Ironcross
Get you self a good hose by the brand "Gates"
Old Mar 9, 2016 | 08:49 PM
terry82's Avatar
terry82
willing to try gates .the aftermarket one did not last long.
Old Mar 9, 2016 | 09:27 PM
goodguys282's Avatar
goodguys282
Old Mar 9, 2016 | 10:38 PM
gbvette62's Avatar
gbvette62
You didn't say what year your working on, so I'm guessing it's an 82, based on your Forum name???
If so, the 82 upper hose is (or was a few months ago), still available from Chevrolet. The part number for the 82 upper hose is 14016075.
Old Mar 9, 2016 | 10:42 PM
mortgageguy's Avatar
mortgageguy
Try Rock Auto.
Old Mar 10, 2016 | 09:53 AM
terry82's Avatar
terry82
I called the dealer .I can still get it $32.02 will take three or more days to get it.had not thought of the dealer .they always have to order if they can get it .The good thing is if they can get it ,,,,it fits. thanks
Old Mar 10, 2016 | 02:48 PM
MelWff's Avatar
MelWff
I thought a bad hose bursts not collapses. It sounds like you have a problem with the coolant recovery system being blocked. As the coolant cools instead of drawing fluid back into the cooling system the hose collapses.
Old Mar 10, 2016 | 05:34 PM
terry82's Avatar
terry82
I checked the line from radiator to over flow tank all clear.The hose was bought from autozone a few years ago .I think its just weak.I would rather replace now rather than wait when it gets hot out.i ordered a gates.Thanks for all replys
Old Mar 10, 2016 | 10:31 PM
tonak's Avatar
tonak
Radiator hoses are under pressure when in function so a collapse is ?
Old Mar 10, 2016 | 10:43 PM
terry82's Avatar
terry82
I also will be replaceing the radiator cap.It may not be releasing pressure.If all that does not work I will do a radiator flush.I just got the car out of storage.could there be air in the system?Will work on it this week.thanks for the replys.
Old Mar 11, 2016 | 10:27 AM
ENCSDOUG's Avatar
ENCSDOUG
Another quick and easy test, pull your radiator cap off and start your motor and watch for flow. I'm assuming you have a 180 degree thermostat and when it opens at 180, you should see water flowing inside your radiator. if not, your thermostat is stuck in the close position.
Old Mar 11, 2016 | 10:49 AM
MelWff's Avatar
MelWff
Default Vacuum
The hose collapses due to atmospheric pressure being greater than internal pressure. This will only occur during the cool down process when the system attempts to suck coolant back into the radiator. So either the center valve on the radiator cap is blocked or the hose going to the coolant recovery tank. The system self purges any air by forcing it out into the coolant recovery tank.
Old Mar 11, 2016 | 11:59 AM
7T1vette's Avatar
7T1vette
The UPPER hose is the PRESSURE hose...so it can't collapse when the water pump is turning-- unless the water pump isn't pumping.
The lower hose [suction side of pump] is the one with concern of collapsing when engine is at elevated RPM's.
Old Mar 11, 2016 | 03:12 PM
terry82's Avatar
terry82
well I looked at the car some more .the hose from the radiator to the coolant tank was not pluged but it was collapsing were it was held to the car .The upper hose is off and it is very soft .it is three years old and made in the usa ,but it was never molded right.a new gates is coming from rock auto.
Old Mar 11, 2016 | 04:13 PM
usmilret's Avatar
usmilret
The collapse can happen when the vacuum valve on the radiator pressure cap does not draw the engine coolant back into the radiator. This happens when the engine and engine coolant cool off. Remember that engine coolant expands when its at operating pressure and retracts when cool.
To upper hose
