Painting steering column
Old Mar 11, 2016 | 09:18 PM
bkemp's Avatar
bkemp
Default Painting steering column
I am going to paint the steering column in my 71, what do I use, Gloss or semi-gloss paint.
Old Mar 11, 2016 | 10:18 PM
69FASTFUN's Avatar
69FASTFUN
I believe it is more of a satin sheen.
Old Mar 12, 2016 | 07:32 AM
Alan 71's Avatar
Alan 71
Hi bk,
I agree that the interior paint certainly wasn't 'gloss' originally.
Whether you use 'semi-gloss' or 'semi-flat' will likely depend on the brand of paint you choose.
I lean toward the lower gloss percentages in 'semi-flat'.
Regards,
Alan
Old Mar 12, 2016 | 09:18 AM
LastBigBlock's Avatar
LastBigBlock
My choice:
Old Mar 12, 2016 | 09:29 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
After checking my steering column on an 80*F day after a 2 hour drive.......
BBQ Black Hi-Temp might be a good choice.....my infrared gun showed the lower part of the steering column was 135*F at the inside firewall (with a 190*F engine thermostat installed/no A/C). The manual steering box was 165*F....talk about heat transfer!
Old Mar 12, 2016 | 10:07 AM
Street Rat's Avatar
Street Rat
I used the John Deere "Blitz Black" part number TY25631.
It's what I used on my engine compartment as well. It is similar to semi-flat black. It is not factory correct if you are looking for something like that.
Old Mar 12, 2016 | 10:18 PM
CraigH's Avatar
CraigH
I used the same Vinyl Paint I used for all interior items. (Some will refer to it as Dye but I prefer to call it paint as it coats items rather than penetrating into the surface)
It has a satin finish.
Details here... https://www.corvetteforum.com/forums...ourney-22.html
Old Mar 13, 2016 | 09:39 PM
bkemp's Avatar
bkemp
Nice work, I think I'll go with the satin finish also.
To Painting steering column
